I installed CHP90 in a small TQWT.
CHP90 is high quality and powerful in all band.
@nandappe Thank you for the informative first hand user report, video, transfer functions and build plan.
I like that it's a 5" driver designed to be relatively flat and extended at each end with a + 89dB spl.
The published 0º Fq Resp plot appears to me to be better than MarkAudio drivers costing more than twice the price. Would be interesting to see a waterfall plot, etc.
Always overthinking ... So what's wrong or sub-par with CHP-90 for it to cost half of MA premeir series yet seemingly have TS parameters that measure better and in use perform as well or beter than the MA premier lines? Production scale vs., closer to hand made Alpair and MAOP, voice coil windings a less expensive off the shelf standard geometry unlike the more rectangular cross section VC wire of Alpair, easier to assemble than MS? IDK?
I don't know the details of CHP-90mica, but the hybrid cone of paper, mica, and Kevlar seems to have opened up a new world.
In total, the sound quality is comparable to MAOP, and 90mica is a cut above in smoothness.
The distorted piano sound is also pleasant to listen to.
Piano is one of the most difficult instruments to reproduce correctly. Well done nadappe. It gives a good insight into what the CHP-90 can deliver. Men's and women's voices are also important.
Glad you like the CHP-90. The price of them is surprisingly good on these units.
CHP90's cost performance is top class in full range driver.
The vocals are good too.
Thanks.CHP90's cost performance is top class in full range driver.
Yes it works great with voices too.
I must test them when they come to europe.
I'm wandering how this driver would perform in the TWTD-10T (my favorite of your designs).CHP90's cost performance is top class in full range driver.
TWTD and DDVP look different, but there is no significant difference in sound.
TWTD-10T and CHP-90 will also produce sound, but with less bass.
Only the lower octave tones, but when I listening to a friend of mine (professional pianist) playing "fortissimo" in his house almost always the sound is distorted in some lower octaves due to explosion, resonance (the dimensions of the room)I don't know the details of CHP-90mica, but the hybrid cone of paper, mica, and Kevlar seems to have opened up a new world.
Many piano recordings that have had a lot of compressors applied since 1990 are distorted.
Recent air recordings.
are also distorted.
are also distorted.
The source is LP ? NICE (I like jazz as it is profound ). By the way , some hours ago I payed for a pair of CHP-90mica and I will receive them in the middle or about 20 of September !!!!! YES YES YESMany piano recordings that have had a lot of compressors applied since 1990 are distorted.
are also distorted.
Do you believe that it is very useful to buy a calibrated microphone (ike the low budget iMM-6) for adjusting the "stuffing" ? (CHP-90mica will be my first Mark Audio driver and I like to have the real experience)The source is a WAV imported from a CD.
CHP-90 mica Enjoy, enjoy.
You will not necessarily need a calibrated microphone since you will ultimately adjust it by listening.
In the future, it would be useful to own a calibrated microphone.
From where did you order them?The source is LP ? NICE (I like jazz as it is profound ). By the way , some hours ago I payed for a pair of CHP-90mica and I will receive them in the middle or about 20 of September !!!!! YES YES YES
" 1% of viewers (measured by total watch time) can't watch this video due to SME claims. "
Sorry. It is available in Japan, but 1% of users cannot see it.
Me too.View attachment 1086064
I asked a pair from soundimports https://www.soundimports.eu/en/markaudio-chp-90.html Have you (or anyother) any experience with Dayton Audio iMM-6 microphone ?From where did you order them?
- Full Range
- MarkAudio CHP-90 mica + DDVP-12.5-ML [TQWT]
