Hi guys
I need suggestion on affordable 100-200ma tube rectifier
Russian tube is welcomed
Thx in adv
Erwin
Thx in adv
Erwin
For a 150ma current (max) you could go with paralleled 6z4/6x4 tubes. There is also a kit:
https://www.ebay.com/itm/265408008128
Some russian tubes exist, but the right use in audio is opinable. See 5Ц4С /5U4S
I just drop with resistor for 5v right? My supply is 6.3vDo you have a 5V supply, or do you need a 6V tube?
Yes. Just beware the rectifier will need it’s own dedicated winding.
Eh ... not really. A 5V rectifier requires a dedicated winding, because the DC output rides on top of the filament voltage. Not to mention that at the current involved, a dropping resistor would burn almost 4W, and that's unnecessary heat.I just drop with resistor for 5v right? My supply is 6.3v
If what you have is a 6.3V supply, IMO you should really only consider 6.3V rectifiers.
Noted. I got it nowEh ... not really. A 5V rectifier requires a dedicated winding, because the DC output rides on top of the filament voltage. Not to mention that at the current involved, a dropping resistor would burn almost 4W, and that's unnecessary heat.
That’s a terrible idea. The heaters should be referenced to ground or slightly above. Now you’re relying in the heater cathode rating of the rectifier.Eh ... not really. A 5V rectifier requires a dedicated winding, because the DC output rides on top of the filament voltage. Not to mention that at the current involved, a dropping resistor would burn almost 4W, and that's unnecessary heat.
You could also run a tube rectifier in conjunction with a diode bridge. That way you get the soft start benefits from the tubes, but the power handling of the diodes.
Ada schematic that do that? ThxYou could also run a tube rectifier in conjunction with a diode bridge. That way you get the soft start benefits from the tubes, but the power handling of the diodes.
When running the heaters at B+ level (which is the case with the 5V octal rectifiers like 5U4, GZ34 etc) you are relying on the isolation of the (dedicated) transformer winding. Make sure it's up to the task.That’s a terrible idea. The heaters should be referenced to ground or slightly above. Now you’re relying in the heater cathode rating of the rectifier.
The EZ81 tube has a heater-kathode rating of 500V (kathode positive), and can be run from a grounded 6,3V heater winding. You can even share the 6,3V with the rest of the tubes.
The EZ81 can supply up to 150mA.
Superb. Thanks alot. Great suggestion. Available locally and affordable. NiceeeeWhen running the heaters at B+ level (which is the case with the 5V octal rectifiers like 5U4, GZ34 etc) you are relying on the isolation of the (dedicated) transformer winding. Make sure it's up to the task.
Two EZ81 in parallel may be just the ticketI just drop with resistor for 5v right? My supply is 6.3v
Is it ok if i use diffrent brand of ez81 on each channel? Would they affect the sound?
It's 2022, why would anyone still use tubes for rectification? 1N4007 all day for me and a properly sized PI filter.
Not really, i doubt its audible, and chances are that two vintage EZ81 are made by the same manufacturer anyway(Philips)Thanks
- Tubes / Valves
- Affordable 200mA tube rectifier
