Affordable 200mA tube rectifier
I just drop with resistor for 5v right? My supply is 6.3v
Eh ... not really. A 5V rectifier requires a dedicated winding, because the DC output rides on top of the filament voltage. Not to mention that at the current involved, a dropping resistor would burn almost 4W, and that's unnecessary heat.
If what you have is a 6.3V supply, IMO you should really only consider 6.3V rectifiers.
Reactions: JMFahey
That’s a terrible idea. The heaters should be referenced to ground or slightly above. Now you’re relying in the heater cathode rating of the rectifier.
When running the heaters at B+ level (which is the case with the 5V octal rectifiers like 5U4, GZ34 etc) you are relying on the isolation of the (dedicated) transformer winding. Make sure it's up to the task.
The EZ81 tube has a heater-kathode rating of 500V (kathode positive), and can be run from a grounded 6,3V heater winding. You can even share the 6,3V with the rest of the tubes.
The EZ81 can supply up to 150mA.
Reactions: JMFahey and kodabmx
Superb. Thanks alot. Great suggestion. Available locally and affordable. Niceeee
Ada schematic that do that? Thx
