You can go off topic anytime you want to me it’s all interrelated at some point and I try to make the connections and appreciate any tangents and welcome them. 😄Yes i agree, it's true for 'hard science' ( physic, astronomy, chemistry,...) but once you introduce human into the equation it's much less an absolute truth ( 'Soft Science' as it was described by one of my teacher back in the day. 'Soft' because your object ( human) is constantly changing his nature and behavior, so the science need to adapt to this hence can't display 'hard' truth...).
As you probably guessed i've got a background in human science (sociology, psychology history, phylosophy,...) and even if math derived application of this science can be scarying ( you know the algorythm that social networks use to 'predict' your behavior and who you should meet or not...) it is still prone to error in their model and treatment of it.
Even the mathematical tools used in this field of human science( statistics) can only be meaningful if correctly implemented and interpreted... which is not an easy task.
It was the point of my comment about the 'partial' part of it. And why i was so interested in epystemology back then... when i was a student.
Booger weldz please apologize for the off topic.
it’s unfortunate that I haven’t been able to point out enough that somebody catches on or sees what I’m trying to say.. (most of it’s my fault because I had a terrible head cold /clogged up and was trying to speak into the phone Microphone and letting it dictate things without really making sure they were appropriately represented, instead of word salad) the point is the enclosures that come as a result of putting things together in this way are extraordinary and unique by anyone’s measure.You can go off topic anytime you want to me it’s all interrelated at some point and I try to make the connections and appreciate any tangents and welcome them. 😄
they’re not necessarily hi-fi .(though that’s not for me to say). they are however, extremely potent , powerful and with very wide bandwidth (if) You’re using drivers that allowed this to happen because they have a real motor force ((BL^2/re) and appropriate TS parameters to go along with it to result in things that are flat wide and ‘proud’ so to speak .
when you line up everything so all freq from 864-21600 (at 864 intervals) and beyond are essentially ‘gone’ you also start at 28.8, override 86.4 (cancelation as the 3 x 1/4 interval/ harmonic and extend to 144 hz (5 x 1/4) as well.
It’s even more interesting using both sides of the comit’s even more interesting using both sides of the cone to See different things and deconstruct in horn response the parts that are dedicated to harmonic parts of 300 or 360 that are required including offset parts to begin with.
it’s a bit complex and of course it’s not possible to just describe using one simulation instead of a couple to compare and contrast a few different things … and hard to explain as a result.
but using a variety of these to compare and contrast it’s incredibly interesting but so are the results!! Offset driver entry in a standard transmission line speaker of 300 cm versus using offsets in 360 cm to what equates to 300 between the drivers in parallel arrangements with the same exit? This is fun once you jump in to see/build/compare, then it’s even more!???
once your canceling out 864,1728,2592,3456,4320,5184 And so on … you have essentially lined things up perfectly( from both sides) and offset yourself perfectly as well… and utilized all of the sequence of odd harmonics found in any pipe resonance calculator for that purpose.
again , your closed mindedness is absolutely worthless to you and the potential that you’re not ever going to see.Oh, I am not talking about you 🙂 but about mentioning Asperger to booger weldz 😉
You can´t be off topic when there is no topic 😉
"Speed of sound", a physical parameter, is definitely not it, and random unrelated numbers with no logic don´t add up to one.
Oh well.
346.4 m/sec
345.6 m/sec
whether you understand or not👽
108, 216, 432,864,1728,2592,3456,4320,5184….
433,866,1732,…
Seconds in units of hours such as 0.9375,0.1875,0.375,0,75,1.5, 3,6,12,24,48,96,192…
or trigonometric functions of angles such as cosin of 30 or 60°
0.866
1.732
The moment you draw this using a 60/60/60 degree triangle that has all four sides as (1732 example) and is then split in half(30/60/90)(866, 1732) as 864 and 1728 it leaves The astronomical unit as long leg (A^2 plus B^2 is C^2.)
1496.492 (864 sq root of 3x864)
864
1728(864x2)
Do you notice down the center goes 09375 and 1875 and 375 and 75 and 1583Do you notice down the center goes 09375 and 1875 and 375 and 75 and 15 30
Well the Pythagorean theorem legs of the hypotenuse and short side pulled over to the otheWell the Pythagorean theorem legs of the hypotenuse and short side include the 13826, 6928, 3464, 1732, 866, 433, 216.5, 108.25, 54.125, 27.0625, 13.03125….
but what you’re really missing is the actual decimal points if you happen to start at 11/2.54 or 22/2.54 or ?? It doesn’t matter you’ll never understand
The thing is what happens in horn response if you line up both sides of the driver appropriately and give it an offset entry point for both sides as well
if speed of sound was 345.6 instead of 344.0 m /sec then all of these with a line two seconds in intervals of hours Minutes and make a unique connection to phase angles as well.
or 346.4 where they all line up to things like 866 and 1732 which should be Noticed as trigonometric functions for 30 and 60°
One look at the definition of a pendulum swing at earths gravity and 30° at 1 m length and you notice a connection is instantly made at pi divided by six which also exist in the volume of a sphere if radius is 0.5 versus one and also exist in the units that are required to make a rectangle six of which to make the perimeter pie. These are also the numbers absolutely 100% necessary to fill the void in the 3×1/4 harmonic our 300 cm 1/4 pie let’s assume that’s 28.8 Hz and 86.4 Hz (3x 1/4 harmonic) at 144 Hz (5 times 1/4 harmonic) and comes full circle.
The math constant for the volume of a sphere is also 240° as radians?
The math constant for diameter is 180° on a circle?
The math costume for 30° is pi divided by six which shows up in all of these and frequency and the paint him swing and so much more what do you look inside the Egyptian pyramid and the great details of the kings chamber
You are correct, much as I tried to visualize a four-sided 60/60/60 degree triangle, I failed miserably. The random strings of numbers preceding and following it didn't help at all, I'm afraid.The moment you draw this using a 60/60/60 degree triangle that has all four sides as (1732 example) and is then split in half(30/60/90)(866, 1732) as 864 and 1728 it leaves The astronomical unit as long leg (A^2 plus B^2 is C^2.)
2992(6.2992) 16 cm as inchYou are correct, much as I tried to visualize a four-sided 60/60/60 degree triangle, I failed miserably. The random strings of numbers preceding and following it didn't help at all, I'm afraid.
1496(31496) 8 cm as inch
748(15748) 4 cm
374(7874)2 cm
187(3937) 1 cm or 39.37” as most of the meter(Those left out decimal points become a tragedy in compound interest or the bigger picture of the federal reserve and the lie hiding in our currency
935(19685)
100cm as /2.54
39.3700787401574803149606299212598….
1,2,4,8,16,32,64,128,256,512…
all missing a little bit each time
Every single time you find something divided by 2.54 the decimal points always have a story was foreshadowing in
is that because the speed of light the meter and the second are that significant in reality?
that a centimeter is actually the diameter of a drop of freshwater at on earth anytime on a flat surface?
still kilogram and then the leader and then the 5 to 36% sphere to cube which becomes a rectangle with a printer on the base of pi but inside Egyptian pyramid that’s 5585 talll vs 5236
349 is The required multiple to find driver entry on any TL to offset the 3×1/4 harmonic it’s also the difference between 5585 and 5236 that is carved out a solid granite inside the Egyptian pyramids as well as 10472
all using five and the square root of two through 21?
748(15748) 4 cm
374(7874)2 cm
935(19685)
100cm as /2.54
The speed of light is fundamental and foundational to the Universe, the units in which it is expressed are arbitrary and of no importance. While the metric system is more rational than the Imperial system, that is mostly a function of its powers of ten relationships. A meter had no more fundamental basis than a foot or a furlong...it started as the distance from the Equator to the North Pole (as it was estimated in the 18th century) divided by 10 million. Every bit as arbitrary as the length of the king's foot. Shifting the reference to a platinum-iridium bar or a number of wavelengths of light make it more precise and reproducible but no more fundamentally rational. While 2.54:1 is the precise relationship between a centimeter and an inch it is otherwise unmagical.
you are a big help , i Appreciate your input so much👍🏻You are correct, much as I tried to visualize a four-sided 60/60/60 degree triangle, I failed miserably. The random strings of numbers preceding and following it didn't help at all, I'm afraid.
This is something everyone should seriously consider ^^^💚The speed of light is fundamental and foundational to the Universe, the units in which it is expressed are arbitrary and of no importance. While the metric system is more rational than the Imperial system, that is mostly a function of its powers of ten relationships. A meter had no more fundamental basis than a foot or a furlong...it started as the distance from the Equator to the North Pole (as it was estimated in the 18th century) divided by 10 million. Every bit as arbitrary as the length of the king's foot. Shifting the reference to a platinum-iridium bar or a number of wavelengths of light make it more precise and reproducible but no more fundamentally rational. While 2.54:1 is the precise relationship between a centimeter and an inch it is otherwise unmagical.
There’s no magic but there is a disaster once you look into encryption(military and 440 hz ) and computer science and the I ordered modes of long-term compound interest or essentially the stock market and jumping on ‘in phase’ like Martha Stewart but in a much more catastrophic scale say Andrew Jackson or Woodrow Wilson instead of the founding fathers original plan ironically in 1776 which happens to be conveniently 30° as 12 on 6.9375The speed of light is fundamental and foundational to the Universe, the units in which it is expressed are arbitrary and of no importance. While the metric system is more rational than the Imperial system, that is mostly a function of its powers of ten relationships. A meter had no more fundamental basis than a foot or a furlong...it started as the distance from the Equator to the North Pole (as it was estimated in the 18th century) divided by 10 million. Every bit as arbitrary as the length of the king's foot. Shifting the reference to a platinum-iridium bar or a number of wavelengths of light make it more precise and reproducible but no more fundamentally rational. While 2.54:1 is the precise relationship between a centimeter and an inch it is otherwise unmagical.
24 on 13.875 (1.375/7)
48 on 27.75 (2.75/7
96 on 55.5 (5.5/7)
192 on 111 (11/7)
384 on 222 (22/7)
768 on 444 (44/7)
1536 on 888 (88/7)
3072 on 1776 (176/7)….
throw those numbers around in some serious astrophysics or quantum physics groups and you have lurking illuminati crawling up your rear and messaging you to join their crooked society of ???
it all sounds silly, Open up Randall Carlson or Graham Hancock podcasts or even ones with Joe Rogan as a host and the Cyclic events surrounding Egyptian pyramid and cataclysms known as Noahs Ark and the active solar system and numerical system that it is involved in all of this I’ve been trying to point out????
I’m not afraid to admit I had head injury or PTSD or both (?) happened kind of recently. then at some point suddenly … this stuff started just flying out of me awkwardly and I didn’t know what to do with it but finally horn response made some connections???
Human brain have some 'strange' tendency: we always try to find organisation within total entropy/randomness.
I suppose it's a way to not going completly nut with what we face: absurdity of life.
It depend of your culture, your belief ( religion), what you've been taught... on how we react to it.
I find fascinating alternative approach to my own system of belief but still i'am doubtful how the meaningness of all this ( mine but other fascinating approach to me): it's easy to loose yourself in some coincidence or seamingly converging unrelated things.
Maybe i'm too much into relativeness of things? The core of atheist's existencial crisis.
it may require some recreational use of psychedelics to unlock the parts of the brain that are far too restrictive or limited for most?Human brain have some 'strange' tendency: we always try to find organisation within total entropy/randomness.
I don’t know (I don’t really use those much in the past, If at all) but I make sure to find relevance and in what i’m trying to represent in more than one place and quickly dismiss snake oil (sometimes even too soon) and then the backtracking to things I dismissed as nonsense prematurely?
Maybe it’s that we can’t barely comprehend beyond the volume or three-dimensional shape of a sphere yet, Thats a pitifully puny representation of reality
imagine what really exists a couple frequencies( if you will) off the ones that we can represent in our limited range of hearing and vision ? after all you can become completely destroyed by radiation while feeling absolutely nothing in just a matter of a half an hour.(Chernobyl first responders /firefighters)
I don't know about drugs. My experience with them didn't unlock creativity in my case.
In my case creativity is linked to how i can either disconect my brain, either accept it as it is without thinking ( kind of meditating state). Drugs are just an amplifier of feelings for me ( a bad amplifier inducing a lot of imd for LSD! Not unpleasant but not a reality i would be in permanently either... 😉 )
Mystical experience have been strong however, and i must say without LSD i would not have been as environementally consient as i'am now ( it revealed my link to nature to me).
That said it seems all computer are strongly rooted into LSD as use of drugs was common when they entered the 'golden area' for hardware development.
That said it isn't a 'safe' experience, i've seen many people selfdestruct with drugs.
I'm not for a free recreational use of it. Or under some rules... a whole other debate.
If your findings have meaning to you i don't see an issue. But be ready to be challenged. 😉
.929516m is 92951600618 hz at 345.6 m/sec
300 m/sec (-51.64 *C exterior angles , hypotenuses, of giza pyramid in Egypt vary 51.84-51.60-51.92) has 866 (0254)
1732(0508)
2597 (0762)
3464(106)
4330(1270)
connection to the cm
So that man made structure holds How much impossible information
1732(0508)
2597 (0762)
3464(106)
4330(1270)
There seems no limit to the amount of mathematics encoded in the dimensions of the Great Pyramid of Giza - if we are to believe all that is published on the internet!
– Pi, the mathematical ratio we all loved at school
– Phi, the Golden Ratio
– The number of days in 1 year
– The metric system
– The diameter of the Earth, the Moon & the Sun https://greatpyramidmath.weebly.com/19.html
– The speed of light…
Don'tcha know that "the Great Pyramid of Giza is the biggest and only time-proof expression of all essential mathematical knowledge known to men". 😵
Still not sure whether we are being collectively trolled or we are witnessing a disintegrating mind ramblings..929516m is 92951600618 hz at 345.6 m/sec
1732(0508)
2597 (0762)
3464(106)
4330(1270)
That's not specifically human, other animals have the same tendency. Chances of survival are better when you occasionally see patterns that aren't there than when you overlook something dangerous. On the other hand, the use of statistics to make a distinction between patterns that probably are and aren't there is specifically human as far as I know.Human brain have some 'strange' tendency: we always try to find organisation within total entropy/randomness.
Well, i don't know JmFahey: it helped me quite a lot when i finally been 'detected' not so long ago (please note i don't use diagnosed):
many differences i have with the majority now have sense and it help keep quiet ( or undercontrol for my side) fears, frustration, anxiety... as well as accept that i am atypical wrt to masses... and be proud of my difference rather than ashamed by it!
Such a relief overall
So you are an Asperger/high-functioning autistic person too? I've known that I am one since 2015. I'm glad you are proud rather than ashamed of it, many are still desperately pretending to be normal. It doesn't rhyme, but: We're here, we are autistic, get used to it!
- Member Areas
- The Lounge
- speed of sound reference
