speed of sound reference
you dont even have a clue? why so rude...
Prove me wrong...compose a three or four sentence paragraph with words that starts with your premise, adds supporting details that illuminate it and then a conclusion that shares what it is you are trying to express. Avoid meaningless strings of numbers that you seem to think are making a point, because you haven't. so far. Language...try it!
l
The reference value used in Hornresp is 344 metres per second, the speed of sound in dry air at 20 degrees Celsius and standard atmospheric pressure. There would have been little point in using as the reference the speed of sound in beryllium for example, which is 12890 metres per second... 🙂.
i dunno, but Apparently no one else does either.. i’m not interested in beryllium or even the atmosphere of Venus😂
but The generic Mac OS X for everything in the big picture are so close to what the ideal gas law just happens to knock off slightly increased this ignorance is something that is eventually going to be a universal understanding in everything in the coming years….
either we start looking at the big picture or we don’t and we just repeat what someone tried so hard to warn us about they built an entire group of buildings all around the world describing it over and over….
The math constants represented there are the same exact numbers at 345.6 m/s and that happens to be 8÷2.54×360
A slightly different version of pie but surprisingly more informative and useful in this case. There’s no such thing as pi there’s no such thing as the speed of light (technically both do not exist , There is not one single perfect circle in all of the known universe that includes everything from the sun which is within 10 miles or siThere is not one single perfect circle in all of the known universe that includes everything from the sun which is within 10 km/6.2 miles ?? weird?
no one suggesting anyone has to change the speed of sound, But at least you recognize some trigonometric functions and numbers that already : 0.866 and 1.732?
Well they’re in the meter conversion to an inch as well in a variety of places and end with repetition every single one of them involving numbers associated with things like 22÷7 or 11 or 5.5 or all the way up to 1 £.76 and beyonWell they’re in the meter conversion to an inch as well in a variety of places and end with repetition every single one of them involving numbers associated with things as 2.75, 5.5, 11,22,44,88,176,352 (usually divided by seven making a reference to a circle kind of like pie,
22/7 is 3.142857
22/2.54 is 8.6614173228..
if I type it nobody looks, and it’s hard enough trying not to but if people don’t wake up and realize there’s a whole Nother form of numbers sitting there and always has been, except these ones are directly related to compound interest jewelers number every single reason why your government ripped you off and continues too..? It’s just higher order modes of anything cycles it just happens to be where no one looks except for the federal reserve an economist with PhD’s in all of this already?
i’m just suggesting somebody take a look I don’t give two sh1ts I got these clowns who just sit around and b!tch? if nobody understands the significance of the meter and the second simultaneously with ??? I don’t know either…
Just move on dude.. I’m having a hard enough time trying to figure out myself? i dont entirely know where this goes, doesn’t seem to end, so don’t ask for solutions to something that was suggesting you look at something already
Climb to the top of Mount Everest, or even just sone high plain in South America or Africa and now your speaker cabinet designed to the 346th decimal place at sea level in New Jersey is now MISALIGNED.
Damn, and I didn’t have enough pack space to bring the DSP.
I am familiar with random text generators, but never found one with numbers. Where did you find it Bw?
Far far away, behind the word mountains, far from the countries Vokalia and Consonantia, there live the blind texts. Separated they live in Bookmarksgrove right at the coast of the Semantics, a large language ocean. A small river named Duden flows by their place and supplies it with the necessary regelialia. It is a paradisematic country, in which roasted parts of sentences fly into your mouth. Even the all-powerful Pointing has no control about the blind texts it is an almost unorthographic life One day however a small line of blind text by the name of Lorem Ipsum decided to leave for the far World of Grammar. The Big Oxmox advised her not to do so, because there were thousands of bad Commas, wild Question Marks and devious Semikoli, but the Little Blind Text didn’t listen. She packed her seven versalia, put her initial into the belt and made herself on the way. When she reached the first hills of the Italic Mountains, she had a last view back on the skyline of her hometown Bookmarksgrove, the headline of Alphabet Village and the subline of her own road, the Line Lane.
Jan
Word salad.
https://www.merriam-webster.com/words-at-play/word-salad
Making Sense of 'Word Salad'​
It describes the disordered speech of the mentally ill.
Word salad began as a term used in psychiatry to describe the nonsensical syntax of the mentally ill.
Word salad is defined as “a jumble of extremely incoherent speech as sometimes observed in schizophrenia,” and has been used of patients suffering from other kinds of dementia, such as Alzheimer’s.
A more technical term for language problems resulting from brain damage or mental illness is aphasia, which means “loss or impairment of the power to use or comprehend words.” Paraphasia is sometimes used as a synonym of word salad: “aphasia in which the patient uses wrong words or sounds in senseless combinations.”
Jan
Could you update the vernacular please?
so do you know anything re: 864, 1728?
The number 864 is a regular number. In music theory, regular numbers occur in the ratios of tones in 3-limit just intonation.
The number 1728 is one I use frequently as a divisor to convert enclosure volume in cubic inches to cubic feet.
The number 1728 is one less than the more interesting Hardy–Ramanujan number 1729, which is famously known as the taxicab number due to its association with a conversation between mathematicians G.H Hardy and Srinivasa Ramanujan.
In 'il saggiatore' Galileo present the idea that 'Everything in nature can be understood through numbers/math' ( it's oversimplified but you got the spirit).
In a way i think it is true but it is partial in my view, it can only be an approximation.
Booger Weldz have you seen Darren Aronofsky's 'Pi' ?
As i've got some trace of it in my personality ( to the point of thinking i was one during my teenage years) may i suggest to take a look at what Asperger syndrom is.
For sake of curiosity at least.
But the most strange of all things happened at my place last winter:
On one day at a certain time it was exactly pi degrees Celsius, up to infinite digits precision.
Even better: I have a broken clock which gives absolute exact time with infinite precision, 2 times a day.
As of:
https://www.barrypopik.com/index.php/new_york_city/entry/dont_talk_about_rope_in_a_hanged_mans_house
Reactions: MrKlinky
Well, i don't know JmFahey: it helped me quite a lot when i finally been 'detected' not so long ago (please note i don't use diagnosed):
many differences i have with the majority now have sense and it help keep quiet ( or undercontrol for my side) fears, frustration, anxiety... as well as accept that i am atypical wrt to masses... and be proud of my difference rather than ashamed by it!
Such a relief overall
Reactions: JMFahey
Numbers in isolation provide no context. Mathematics, which places numbers into a context of their relationship to each other and to physical phenomena are the key to our understanding of the Universe. Discoveries in mathematical theory often presage and illuminate discoveries in physics and other scientific disciplines. Einstein's general relativity used geometric mathematics earlier developed by Riemann to make the predictions of physical phenomena that still stand the test of time.
Yes i agree, it's true for 'hard science' ( physic, astronomy, chemistry,...) but once you introduce human into the equation it's much less an absolute truth ( 'Soft Science' as it was described by one of my teacher back in the day. 'Soft' because your object ( human) is constantly changing his nature and behavior, so the science need to adapt to this hence can't display 'hard' truth...).
As you probably guessed i've got a background in human science (sociology, psychology history, phylosophy,...) and even if math derived application of this science can be scarying ( you know the algorythm that social networks use to 'predict' your behavior and who you should meet or not...) it is still prone to error in their model and treatment of it.
Even the mathematical tools used in this field of human science( statistics) can only be meaningful if correctly implemented and interpreted... which is not an easy task.
It was the point of my comment about the 'partial' part of it. And why i was so interested in epystemology back then... when i was a student.
Booger weldz please apologize for the off topic.
Reactions: Booger weldz
Oh, I am not talking about you 🙂 but about mentioning Asperger to booger weldz 😉
You can´t be off topic when there is no topic 😉
"Speed of sound", a physical parameter, is definitely not it, and random unrelated numbers with no logic don´t add up to one.
Oh well.
I didn't take it for me JMFahey, it's just that when you have one of this 'strange' brain, you don't usually know it beside it's obvious to everyone with a bit of attention to you ( the patern are subconscious driven so unavaillable to the one subject to it).
In my own case i was into deny for maybe 20 years: my younger brother was the first to talk to me about it but i could not believe him at the time. I took long period of time to accept i'm different from the crowd ( as one of the thing i want the most is to be like everyone else!). Not an Alien but strange enough to trigger ( usually 'bad' for me) reaction from 'normal' people when i express my concerns or interest in life.
Anyway from previous description Booger Weldz did of his scholarship and life itinary i would advice to dig and have interest about atypical profile, just to see if by chance there is things that talk to him ( especially if he have issues in life: social interaction, social isolation, isuue with self confidence,...things like that). It helped me to put things in perspective, brought back confidence and made my life easier. And WITHOUT pills. 🙂
It did not cure my dislexya though...
