Class D Amp Photo Gallery
Customer build.
Reactions: Phloored
Hi All,
Sharing an SMD amp I put together using a TPA3116D2. Schematics and everything available here: https://www.jcracoustics.co.uk/plans/
YouTube tutorial available on the design build as well here:
This one has Bluetooth and Li-Ion Charging built in. Just posted a new thread on it for those wanting more detail!
Let me know your thoughts!
Hi all
This is my project, it is not finished, Is a tri-amp system using TPA3255 with active crossover
I already test the crossover and they worked, the next phase is to finish the amp board
The system consist of
2 TPA3255 3E audio Boards for sub 100hz
1 custom TPA3255 amp above 100hz
Custom power boards
this is my first design so I made some mistakes but I have learned a lot
Reactions: decramer and rrobot
A month later and I have a working amplifier!
This proof of concept includes:
  • IcePower 300A2
  • MicroAudio SMPS630-G
    • +-50 VDC
    • +-15 VDC Aux
    • +-12 VDC Vdrive
  • Additional capacitors (2*10000uF per rail) between SMPS and amplifier, also from MicroAudio
  • 300A2 wiring harness set from Ghent Audio
  • Cheap UPC1237 speaker protection board from Amazon
No one else is in the house for now, so I can temporarily justify the precarious setup to test out the amp. Preamp is an ACP+ and the source is a Squeezebox. Speakers are Manzanitas.
It sounds MARVELOUS. Absolutely silent background, even with this mess of cabling. Zero noticeable power-on or -off transients. The very little heatsink on the 300A2 is warm, probably around 45C. There is plenty of detail and power available. I love it, and since it’s the latest amp I’ve built, it’s my current favorite. 🤓
My chassis plan is still in flux.
Thanks to Sami from MicroAudio and mdsimon2 for the support to get me to this working prototype. 👍
Reactions: Cresnet
Thanks, Vunce. It IS amazing. Tiny little thing with BIG, lush sound.
It is really difficult to disconnect the VFET from the system, but I like cycling through my little collection of toys. Putting this one in a chassis will need to happen soon. It’s worthy.
Reactions: stewin
I’ve named it The Sleeper.
Classic Hitachi lateral TO3s on the back for bling. :devilr:
Meters aren’t moving, yet, but I couldn’t resist an audition.
Sounds great. A little mains hum that I will track down later, but it’s not noticeable more than a foot away.
Big Summer Amp is live.
Here is a tpa3250 board I put together for my bass shaker project.
It uses a modified 36v 5amp smps that was $14 on Amazon that is adjusted down to 32v.
It is a dual mono with a single input and two active preamps with volume and frequency adjustment. For this project the preamps are just single supply and I powered them with a step down buck converter off from the main supply.
I was going to use this board for another project but just decided to build this for the bass shakers. They are 4 ohm and 50w so this should be more than enough. A 3116 would have probably been just fine but they are 4 ohm so I would really want dual 3116 chips anyway and I already had this one...
The IEC is a little bit tighter to the smps capacitor than I would like but it really isn't bad.
I left just a little room to add some power supply cap between the smps and the amp but I haven't done it yet.
I am working on another subwoofer based on a tda8954 but I am still not quite happy with it. That bigger amp uses a dual supply preamp and a dual 36v smps.
And finally I need to finish my 5.1 surround sound project. It has a IR controlled preamp, a dolby decoder, 3 mono tpa3116 and 1 stereo tpa3116 boards.
Reactions: stewin
I Just completed a 6 channel Starkrimson, with boards spanning 3 different revisions. Originally 4 of these were powering my main speakers, but I need more power for those, so they have been re purposed into this 6 channel build. It is powering my side surrounds and atmos speakers. All measurements were taken with a QA-403, and every amp hits specifications no problems! Channel 6 idle noise is a bit higher then the rest, and some mains leakage due to the proximity of the IEC connector, but nothing audible.
The difference from running the 6 speakers from my Yamaha RX-A6A to this amp is night and day, and I honestly was not expecting such a drastic change.
3 channels each are powered off of a Microaudio SMPS630-SO power supply, which I have used before in my Class AB Wolverine amplifier builds, and are fantastic low noise high power supplies!
Thanks to @stuartmp for The ground lift and T-ground PCB's
Thanks also to @Cresnet and @orchardaudio for making such great products available to us!
  • Starkrimson x 6 Amp.zip
