Acoustic Horn Design – The Easy Way (Ath4)
Calculated again at 2m distance (seems the previous sim was not in far-field enough).
Horizontal, vertical, diagonal:
The dimensions are 624 x 448 x 328 mm (W x H x D).
If you started like this with a square mouth that is made from Flexi-ply and a laser cutter (cheap and very easy!- this would take 30seconds machine time)
Those that cannot access a laser can draw out the coordinates on the wood manually
You would have to check/be careful of the max Bend radius, (looks ok by my guess)
The mouth radius of a horn like in #10238 (DS8-T12?) will be very difficult to bend without siping or steaming even using plywood as thin as 4mm.
Multiple layers to reach around 12mm thickness are required to keep the wood non resonant.
The ply is a special type with a rubber middle layer and vineers on both sides that run in the same direction. The stuff can be rolled into approximately 200mm ring without signs of cracking.
...can be as good as this (480 mm mouth size / 1.5" throat):
so obviously bandwidth is AMAZING. but its really not as smooth as your axisymmetrical designs. do you think it would be clearly audible? wouldn't the best still be a large axisymmetric? Are you just weighing up the ease of construction here? For good engineering always need to balance these two ofc. are you hoping do listening tests against your large old ones?
Joined 2004
I am, of course. But at the same time it was a sort of a revelation that the shape itself doesn't cause any problems regarding smoothness - see #10,175 where it was in an infinite baffle (the intuition just doesn't work here). It's all about termination.
As for the audibility, my guess is that this already approaches a threshold where it doesn't make a clear difference.
As I already have rectangle I can easily modify the code to make 8 or 6-sided polygons just by shifting the position of the corner point, still preserving the 1/4 symmetry. For anything else I would have tp rewrite much of the code and I'm not sure it's worth the effort - the are actually no parallel walls even for a rectangle. Yes, it's symmetric, but that's a circle too (far more symmetric) and it works fine.
