Exploring Purifi Woofer Speaker Builds
Norman: "Many hours of CNC and sawdust later its 12 liters for me. Is the result in the listening room superior for 12l due to something like the max-flat alignment having better group delay &/or critically damped transient response?"
And the answer is .. yes ? Would you say that a sub is recommended here ?
Need for a sub is to my thinking a multiple choice answer with three options:
A. No subwoofer needed.
B. Subwoofer absolutely needed.
C. DSP and/or more PTT6.5s or 8s needed.
For my day-to-day use its "A" no sub. The PTT6.5+PRs get to below 30 Hz in my room and when movie directors add really deep sonic effects they are clearly audible. The tracks on my music centric bass-demo playlist result in dropped jaws and exclamations of "did you hear THAT!" I believe part of my satisfaction is my typical listening levels averaging below 90 dB.
Add in a strong home theater mix or musical tastes and listening levels running to the Ministry Of Sound Classical concert cited above and your answer is "B" bring on the subs. I would not advise hitting a PTT6.5+PRs system without high pass protection with the trip-wire scene from 1917 at THX level. Those applications are why 15" subs are so widely available and 18" and even 21" woofs keep coming to market. I'm working on a post on how I overloaded the PTT6.5+PRs using a classical music piece with the volume control and EQ at silly levels.
Option 'C' is looking forward to an attempt to reset the state-of-the-art with bass depth and output capability along with the industry leading low distortion PURIFI brings. I expect most of you know it is very common in modern powered subs and advanced table top all-in-ones like B&W Zeppelin and Naim Mu-so to combine bass boost below system Fs along with dynamic limiting. The 'oh-shyt' moment I metioned above occured while I had the EQ elements of that enabled and got complacent and left soft dynamic limiting on the To-Do list. The glimpse I enjoyed of what lies on this path was very tantalizing. Start adding multiple PURIFI woofers per channel and (IMHO) it will reset the state-of-the-art for both bass depth and distortion at high levels.
Reactions: julbo and lrisbo
Not a stupid question at all. Recall in bass systems using vents or PRs the woofer(s) provide most of the output, until the tuning frequency. At that frequency where the box is tuned the ports or PRs take over and provide the sonic output. At the exact tuning frequency the pressure of the air in resonance holds the woofer almost still while the PRs (or air in vent tube) experience maximum excursion. The graph below is the Stereophile measurements of the GoldenEar BRX also a woofer + PRs system. The blue trace is the woofer output, red trace the PRs outputs. Notice just below 50 Hz woofer output drops while PR outputs peak. Black trace is where they sum to yield the combined system output.
Thus with woofer on front and PRs rear configuration they are not acting in anti-phase therefore minimal cancellation of Newtonian forces.
correct. below the tuning the woofer and PR are getting out of phase so forces are more like reinforcing rather than cancelling. There might be a frequency range where there is a bit of cancellation but it is for sure not wide band. The net force can of course be calculated and plotted with a bit of math/physics. The side mounted PRs cancel forces from a simple symmetry consideration
Reactions: emilkoz
Let's get real. My prototype design with the PTT6.5X-04" in a 21L box, using a regular ol' 2.5" diameter port, goes all the way to 35Hz (F3). People said it couldn't be done, but it can be done, if you pay attention to the power handling, excursion and air velocity at the port tuning frequency, and remember to include the baffle step losses.
It doesn't start to complain until about 99dB @ 40Hz. Power handling drops like a rock below 30Hz, but honestly there isn't much musical content below 30Hz, as demonstrated on my FFT of the live concert.
Which is only 10dB less than the enormous speakers that they replace, that are 6 times as big, and almost twice as wide, and 3 times as heavy. Besides, these big speakers spend half their time at 0dB (off), and no-one in my house wants to look them either. 🙄
When Scan-Speak came out with their 18W midwoofers, with 6.5mm excursion, it really put companies catapulted companies like Wilson Audio, Sonus Faber and ProAc.
Now in C21 Purifi Transducer Technology shows that they can go on step further... 🥷
Small is in, and it's here to stay...
Size reference-55” TV
Similar figure in Vituix with 2x Purifi PRs, 12L volume. Between 30Hz to 150Hz there's a clear in-phase PR component that adds up to the main driver SPL. There's an out of phase component as well that will contribute to the cabinet "rocking" if PRs are rear mounted. Tried to figure out the out of phase energy component via LTSpice that is not cancelled out, does not seem like much yet not sure I got it right though.
Reactions: emilkoz
The Newton forces are simply mass times acceleration for each driver (and hence goes to zero towards 0Hz). At the tuning frequency the PR’s do most of the SPL, ie they have most of the acceleration whilst the active driver excursion is at minimum. since the PRs are much heavier than then active driver they produce much stronger forces than the active driver for the same SPL (eg if the driver was in a sealed box). Having two PRs instead of one quadruples the total mass needed to keep the tuning frequency whilst area doubles. That doubles the Newton force for the same SPL. The least force is obtained using a port (small area low mass high excursion). But even a port gives Newton forces - although it is a bit mind twisting to imagine
The other thing to be mindful of, is the proximity of the passive radiators to the active one. Midrange leakage through the PR cone is a real phenomenon, and If using dual PR I’d try to keep them as far away from the active driver as possible.
btw, @mainframe
Yevgeniy’s released plans for his 6.5” 2 way.
full plans to build your own are now available, and a small price to pay, I’d say, for builders looking for a solid design, with an excellent tweeter too:
https://hificompass.com/ru/projects/2-way-systems/puriwave-purifi-ptt65x08-nfa-01viawave-srt-7
btw, @mainframe
How do you source the Viawaves these days though?
Updated 16/06/22: Added builds and review links, updates to builds
Update 17/03/22: below
Time for a bit of consolidation due to this thread getting some hits, and purifi has now released quite a few scrunchy woofers
Links to known projects & commercial speakers using the Purifi drivers (please PM me if I need to add any)
Of course - www.purifi-audio.com , and the team behind the drivers here
Full DIY:
Check out this 4" pocket rocket proof of concept build from the Purifi team - all the info you need to DIY!
Spk8 appnote download (.pdf)
@lrisbo Proof of concept Purifi SPK4 (superseded) - Passive stand-mount
@lrisbo Proof of concept Purifi SPK5 - Passive stand-mount - I believe these were at some point being made and sold commercially but have since been discontinued - there may be some floating around second hand market see here Celuaris SPK5 review ASR
@xrk971 PTT6.5/RS28F Waveguide Harsch XO - Passive stand-mount later evolved into a nice Stand mount and Floor standing Transmission Line
@Joe Rasmussen Somewhat Legendary 'Elsinore' - Has been given an (expensive) purifi remodeling. Wow. Skip ahead to post #4,746 for the juicy bits.
Rick Sykora and team's Directiva - Active stand-mount with excellent (objective) reviews, requires external amplification for each driver and an external DSP crossover.
@xrk971 's Raal 70-20xr and PTT6.5 - this one the tweeter is not readily available to DIYers but there may be ways to get it if you're crafty.
(sorry X, couldnt find a finished pic, and I'm out of attachments for this post)
.....and many more concepts within this thread, start reading. Most not fully documented or taken to finished stage though I suspect a few people are still perfecting their builds before showing them off. Remember you can drop people a friendly private message asking about how their progress is going.
DIY-Kits/Semi Commercial:
Yevgeniy’s PuriWave - 2-way stand mount with dual purifi passive radiators
Troels Gravesen Purifi 6661 - Semi-passive/Active plate amplified floor-stander
Troels Gravesen Purifi 6R - Passive bookshelf
hificompass Puri Bliss BeWg - Passive bookshelf - I believe the plans are/were for sale
Joseph Crowe's 1198 - I believe you have to get in touch via the webpage - floor-stand transmission line
Full Commercial:
March Audio Sointuva - arguably where "the bar has been set" for the Purifi 6.5 in a bookshelf chassis.
Jones Scanlon Baby Reds - self powered studio mixing monitors.
The Late Rick Craig's Selah Audio Purezza - A nice stand mount ribbon tweeter design, was available commercially but afaik discontinued, check SH market
Jachim Gerhard Surveyor's - stand-mounts , I believe there is/was a floor-stander made too
Dennis Murphy & Jim Salk's BePure2 - Floor stander - The legends behind the philharmonic BMR and BMR tower
and um, what ever this might be! https://www.audiocircle.com/index.php?topic=175599.0 - probably just a concept, I didn't read the thread. Likely Unobtanium tweeters and probably bottomless pockets required, if it is sold commercially.
Correction - the above was a concept which later evolved to the BePure2 - see this thread at AVSForums Post #10,174
https://www.avsforum.com/threads/th...rs-and-discussion-thread.939744/post-61186397
Links to independent driver reviews:
https://www.erinsaudiocorner.com/driveunits/purifi_4/
https://www.erinsaudiocorner.com/driveunits/purifi_ptt65w04/
https://www.erinsaudiocorner.com/driveunits/purifi_ptt80x04-nab-02/ - the eight inch aluminum mid-woofer
https://www.erinsaudiocorner.com/driveunits/purifi_ptt6.5x04-naa-08/ - the 6.5 inch aluminum mid-woofer
https://www.erinsaudiocorner.com/driveunits/purifi_ptt6.5m-08-nfa-01a/ - the 6.5 inch dedicated midrange
Also - please consider visiting Erins Youtube Channel and subscribing! - a much needed light in the dark world of audio subjectivism.
https://audioxpress.com/article/tes...udio-6-5-midbass-transducer-from-purifi-audio
https://hificompass.com/en/reviews/purifi-audio-ptt65w04-01a-midwoofer
https://hificompass.com/en/reviews/purifi-audio-ptt40w04-01a-midwoofer
https://hificompass.com/en/reviews/purifi-ptt65w08-01b-ptt65x08-nfa-01
https://hificompass.com/en/reviews/purifi-ptt65m08-nfa-01a-65-true-midrange
http://www.troelsgravesen.dk/Purifi.htm
Original Post 02/04/2020:
With the group buys well underway the idea was bought up that a design thread be started to discuss build options.
Mine have arrived but I have no build materials and will not be able to get any until we come out of quarantine in (hopefully) three weeks time. I planned to start with a hybrid of purifi's SPK4/5 builds using the same AMT tweeter but maybe using a slot port with the 2.5khz crossover. That and I haven't done any AMT builds so it seemed like a good place to start.
I read of a guy in Aus planning on doing a line of passive and active speakers with the woofer so be interesting if he could chime in here.
So with no materials for the next at least 3 weeks, what better time to discuss build options! Fire away
Great overview
Reactions: lrisbo
