LED keeps blowing on AC supply
Apparently many don't see that but I am glad I am not the only one that does see it. Since they were intended for DC use it seems the simplest and most optimal way of dealing with them.
* It is a current limiting resistor. Dropping resistors limit voltage AFAIK.
Well the diode has a Vf that is within a small window and all the rest of the voltage is then "dropped" across the resistor, right? 🙂
Diode, 22 kOhm series resistor (for 24V AC), 1 ... 10 µF cap, second 22 ... 100 Ohm series resistor + LED.
High part count for an indicator light.
I hate this thread already.
No hate just love. You should add the main current limiting resistor and the antiparallel diode I forgot to mention based on the info Elvee provided (I think). It was the leakage current of D1 that made the LED blow up. This is prevented/solved by adding the antiparallel diode. R1 was meant to overcome the issues that come with the LEDs parameters in combination with a parallel cap as mentioned by Elvee.
Blue LEDS of today are different. They lighten your whole living room at 1 mA. Well, almost. We learned that they are also quite sensitive to reverse voltages.
One could use a diode-cap-voltage regulator-cap-series resistor-LED to overcome all the blue LED issues 🙂 The anti-KISS approach.
I would use a 'normal' LED, this is complicated, and failure prone.
Use a bridge rectifier, drop / current limiting resistor, smoothing cap, 3V9 zener (if needed), as a possible supply. Pure controlled DC.
Alternately, 22V SMD LEDs are available, used in lamps, bulk packing.
They will not blow up so easily.
Nice circuits, especially the second one with standby indication! Almost more complex than the device they are built in 🙂 Hey if it floats your (blue) boat....
Some hesitance to bring higher voltages to a front panel LED though. In the past a few extra windings on the toroid with normal insulated wire to the standard green LED and just a series resistor also worked. Safe, simple, cheap and reliable.
Reactions: wiseoldtech
You're right!
But I wanted an indicator each for on and off state. Wouldn't work with voltage from the switched transformer.
The LEDs also aren't put directly in the front panel. I would see isolation issues with them looking through a metal panel.
The panel is either of transparent Plexi and the LED is shining through it (Like here).
Or there is a kind of light guide from Plexi which reaches trough the panel.
Why easy when it can be complicated 😀
Reactions: NanoFarad
Yes that is the spirit. I just disassembled a device that can only be disassembled destructively (nice) and that one has a microcontroller for standby, power on and the LEDs blinking.
Wow! That link directed me straight to hardcore electro-porno. Never do that again.
As I've always mentioned, I like to keep things simple, and thus reliable.
One amp I'm working on uses a blue/red LED for standby/on, DC powered from a tiny standby transformer which also kicks in a speaker delay relay.
The 3 position source selector also powers 3 LED's - blue for phono, red for CD, and green for aux.
That sounds like a modern bicycle light, one of those battery-powered models that are not permanently attached to the bike. I frequently find damaged ones on the pavement or the street and then re-use the LEDs.
Wiseoldtech again... with even 2 blue LEDs to laser the eyes 😀 I take it is blue for power on and red for standby?! Otherwise many would be switching stuff off instead of on.
Yes Jean-Paul, blue for ON.... red for Standby.
CORRECTION: Both are OFF when unit is OFF.
The red illuminates at power ON... then switches to BLUE when the delayed speaker relay kicks in.
And they both are dimmed to a comfortable glow and show through a single frosted lens, as are the selector LED's
I dislike bright LED indicators.
