"Upgrading" Amp drivers capacitors
I do not believe that connecting them together in parallel (MOSFET and BJT), and placing them in a circuit (as shown) -> is possible... at all.... ...wouldn't work correctly without changing the way MOSFETs / BJTs are driven....
Also my thoughts, but wasn't shure: I assumed either there is something very sophisticated which I don't know or simply nonsense.
Reduction of resistance. The device contributes to the output impedance.
The TIPC isn't connected to the output line (there's no blob).
Hmmm... now what?
Hi All,
Just wondering, Would be any benefit in using higher value capacitors in an amplifier's driver stage? currently there are 220uF in the circuit, would be any benefit in replacing it with , let's say 1000uF capacitors?
I'm referring to the marked capacitors in the attached schematic.
C12 also sets the low freq corner. If you increase it a lot, you'll get a lower LF corner which may cause very low frequency movement of the speaker and possibly LF oscillations aka motorboating.
It would be smart not to tamper with it too much.
Jan
Reactions: ejp
jan.didden said: It would be smart not to tamper with it too much.
In amplifier simulations (LTspice) I noticed the following:
The feedback DC blocking capacitor adds distortion in the lower frequencies, e.g. below 500Hz, depending on the capacitance and the current flowing through it. Rising it's capacitance lowers the distortion, respectively shifts it further down. Increasing the value of the resistor in series with the DC blocking cap also lowers the low frequency distortion; of course in this case one has to tweak also the feedback resistor to reach the equal gain.
How big do you think this capacitor can be? I've seen circuits with e.g. 1000µF or more for it.
In the "TO39AMP" I'm working on now I'm using 470µF.
Could c10 be swapped for 1 uF only but mkp radial ? More damped sound and improved subjective transcient...worth to try ?
0.1 uF across the 220 uF of the zener for improving the filtering ?
Also what is the c10 brand and model (leads spacing)
Of course. You're modifying the feedback level and that translates in changes in distortion profile. It's not as if 'the cap adds distortion'.
The way to calculate is first decide on the lower cutoff in your freq response, then calculate the cap value for that Fc against the resistor in series with it.
Jan
Reactions: ejp
Thanks. Here's the cleaned-up photo:
Thank you for mentioning it.
Isn't the amplifier's LF corner 1.54Hz? please correct me if I'm wrong.
Just want to add: this is already excessive, any rumble or LF junk will gobble up power and may damage the woofers. No idea who decides these nonsense cap values.
22uF for a 15Hz lower 3dB point is much more sensible.
The mind shudders with talk of an upgrade to 1000uF ...
See attached graph with 22uF showing a -3dB point of about 15Hz. (Assuming series R of 22k, hard to read on the pic).
Jan
  • fb.asc
    fb.asc
Reactions: Sandm0n and ejp
Never thought about photo rumble affecting an amp like that.
I had flapping woofers and a power amp repeatedly shut-down because it was "DC coupled" and did not like my phono source.
OTOH, Doug Self and others preach over-size electrolytics to avoid distortion. (The take-away is a few film-caps to define a sane bass roll-off and any e-caps much larger.)
Jan
Thanks for the explanation.
R46 is connected in series to C12, it's value is 470 ohm.
