DAC AD1862: Almost THT, I2S input, NOS, R-2R
Do these Frolyt cousins still remember their poor relatives from the East? Which often went kaput with less than 170hrs 😛.
Hi, on this board the DAC chip AND the opamps share the same +-5V psu. The AD1865 analogue part needs the +-5V, so you can't just raise it to +-12V. If you want to supply the opamps with +-12V, you need to supply it separately and then you need 3 psus. You just have to remove two of the jumpers (probably J10 and J11) and apply the third supply there.
miro, i tried all of yours pcb, ad1862 with headphone amp, ad1865 v1.1,1.3 and jlsound version, would you consider to make a gpio 40 pins version for raspberry pi? i think the connection between the pi and the dac as short as possible, i tried 5, 10, 15 ,20 and 50cm flat cable and 10, 20 cm dupont cable, 5 cm ,10cm flat cable and 10cm dupont cable no different, but 50cm, the sound likea put the speaker in the toilet, very funny.......
now my connection is through "i2s to hdmi pcb" > hdmi cable > "hdmi to i2s pcb", sound beeeeeeautiful, anybody who finished the pcb, try this, no expensive but will give you suprise when the sound come out.
Reactions: miro1360
For the best sound experience avoid direct I2S output from the rpi. Instead use the rpi USB and connect here a high quality USB-I2S device with clean clock (like jlsounds or another xmos based ... I think even the cheap PCM2706 with rpi USB will sound better as direct I2S from the rpi) 😉 ... someone in this thread tried it ...
In the future I can create 40 pins version also for RPI, but it will be the stop-clock 🙂
