Markaudio drivers from the bottom to the top of the line question?
Good morning everyone 😁. I know Mark Audio Drivers have been talked about their measurements and debated on this forum and other forums as well about this subject. I did have a few questions that I need clearing up before I buy a set for a project? So here goes? (Pardon my repeated questions if they have ready been asked?).
1. The new Magnetic Arc Oxidized or (MAOP-5 Driver’s). Do they Really sound that much better next to the Alpair 5 Gen. 3 drivers? Or the 7MS drivers? Iā€˜Ve read it’s a very expensive process to make the cones? What do they sound like? And are they worth the money? 😬.
2. So I see that some of the design for the lower end Mark Audio drivers are following suite to the more expensive drivers. Like a dimple in the middle of the dust cap? Or two round circle lines in the middle of the Pluvia drivers? Does this really make a difference in sound? Or the Dispersion of the distortion coming off the drivers dust cap? (If I wrote this right and am understanding it right?). I would enjoy seeing the before and after measuring of these two dust caps against regular Mark Audio Dust caps?
3. Last question? Or questions? When you up the line with Mark Audio are the metals better that he is using for the cones? I know they upgrade something’s and the shallow profile of the cones curved shape.
I will say that I have never heard a metal driver sound more towards the warmer side like the Mark Audios I heard. ( So use to the Fostex sound). So I do give Mark and his team credit for always trying to meet the challenges of the past full range driver issues and addressing them. Thanks for your help. Jeff
1/ i look forward to hearing MAOP 5.3.
I have only heard a MAOP 7. MAOPs are decidely top of the heap, and worth the extra tariff. A7.3eN gets really close but those are diy now.
MAOP 5.3 would be the first MAOP with monoSuspension and, in theory, should be the most accurate midTweeter MA makes. Only downside is the small come might lack the dynamics you might want. That same small size also means it is much easier to control the HF chaotic/TL mode of operation.
2/ dimple on the dustcap seems to help deal with ringing in the dustcap.
3/ i cannot say for sure, i would suspect the metal is the same, but the refinement of the cone is not.
Before MA (gen , gen 1 not) i had the typical generalization towards metal cones. These (most of them) have shown that it is not inevitable.
dave
Reactions: sser2 and navin
Good Evening Dave. Sorry for the late reply. I was trying to remember what Mark Audio Drivers had the 2 rings around the outer dimple in the center of the dust cap? Now the news ones don’t? I did have set of the Mark Audio drivers like this but, sold them a long time ago. I will have to look for a picture of what of talking about? Sorry if it did make sense? Jeff
Thank you @planet10 , @Scottmoose
I visited Mark Audio's MAOP 5 webpage https://www.markaudio.com/online_shop/5-cm/maop-5-2/, but didn't see any mention of mono suspension or spiderless construction.
Guess I have to take your word for it! šŸ˜‰
In the meantime a pair of Alpair 7 MS should arrive in the next few days; the plan is to design a streamlined cabinet along the lines of Denso Ten's TD508 / TD510.
cheers, jonathan
The only new drivers from Mark Audio are the
MA200-M Multi Midnight Copper.​
They are so beautiful looking and the biggest driver Mark Audio makes and is a true 8ā€ inch full range. I checked and Madisound has no mention or news on their web site. I will e mail Adam or berry? I Will give an update when I get onešŸ‘. Jeff
Reactions: seventenths
Sorry I have been away for a while and should have said new to me. Scottmoose if anyone knows what’s new or not your the guy. šŸ‘šŸ˜Š
My wife said the color on the Mark Audio MA-200 Multi mi’d night copper is beautiful and is a high wife acceptance driver. Awesome Job. 🄰
By the rings, I think you might be referring to enabled drivers, which is a mod people do to their own. This is what Dave is referring to when he says "eN" at the end of a driver name, such as 7.3eN.
If you look at post #12 on here you'll see the rings
Markaudio recommends 2 L sealed for MAOP-5, F3 about 180 Hz.
MAOP-5 is problematic because it is rated 5 W but it is 4 Ohms, so it is not suitable for most solid state amps. However, it is perfect for a low power tube amp like a 300B SET or SE pentode with 3 - 8 W output power.
I bought a pair, they are currently breaking in, but projected to surpass MAOP-7 in clarity and detail. The best mid-hi driver I've ever heard.
