the speed of light and the 1/4wave speaker
Nothing unique or interesting here…🤦🏼‍♂️
Its 1133.85826ft/sec at 345.6m/sec.
it happened To be 73 1/2° out this morning… imagine that..
(So what)…. Thats not the point.
Whats the fournier analysis of these numbers?
Gotta love numerology:
1/9 = .11111---
2/9 = .22222---
3/9 = .33333---
4/9 = .44444---
5/9 = .55555---
6/9 = .66666---
7/9 = .77777---
8/9 = .88888---
So by logical extension
9/9 = .99999--- 😊
Please… The kindergarten stuff isn’t part of this discussion. Take your horoscope with you too…
Iif you cant find it in math ( and also independently in horn response) And if you cant come up with it In another form or Place distance time interval etc. get it out of here please.
if there’s something to see here it’s real.
If r is 0.5, V sphere is 0.5236/0.5238 rad)
ir r is 1.0 V sphere is 4.1887/4.1904rad)
4.190476 is 240
0.5238 is 30
8:1
a sphere Placed in a cube which has a length width and height of one displaces 52.36% volume.
this comes from the meter by way of the milli liter as in a kilogram of water. as one drop of freshwater is 1 cm in diameter anywhere on a flat surface on earth.
0.5236 is the ark of a pendulum swing in one second the straight line distance of that between the two would be .5… each side of that swing in the arc is 15° but that is also 0.2618
0.618 +1 is 1.618
(1.618)^2 is 2.618
15° and 30° are the equivalent of parallax angles of the speed of light and half the speed of light.
How distances are determined in astronomy (notice I didn’t say astrology).
A hertz is equivalent to the conversion between the inch and a meter, to km and a mile
but first you must go through the Pythagorean theorem.
and you must describe a circle as 360 cm in 2pir.
r is 1.
Or its 39.37…(1/2.54)????
and the sun is pi.(almost exactly)
C= 2pir
pi is C/D
calcula
Offset driver TL 300cm(speed of light(x-100000000, speed of earth(x-1000) , etc
300cm
X0.349206349
is 104.761904
(X3)
Is 314.2857…
300-104.761904..
Is
195.238052380…..infinite
195.238095238/104.7619047619
Is
1.863819499140349.(~speed of light in miles per sec) all those numbers (instead) to the regular ‘pi’ number (or better yet the actual size of the sun defying the pi number) and look what happens..
intersting… open mind not eyes wide shut
WHAT are you talking about?
For Humans, Acoustics deal with Air, a MOST compressible fluid.
We are not designing Dolphin communication or submarine detecting Sonar transducers here.
Just as one extra example, think what happens in an acoustic suspension cabinet filled with ... duh! ..... Air.
Now imagine same cabinet filled with an incompressible fluid such as water.
Do you say both will work the same way?
Just curious, is today Fool´s day or similar in some Country and I am not aware of it? .... just read the nonsensical Numerology thread.
Shivering about what I may find next.
Wgeres the Numerology thread?? I would love to read that it’s a another filter to use to get that junk out of the way..it plagues everything. Esp science as you said
(1728)^2 - (864)^2 is 1.0AU. Sq root(149649189…)
1/2 speed pf light or 500 seconds (1/2 Pendulum swing As pi divided by six)
Fournier discovered a specially gross kind of gangrene, I´ll spare you the puke inducing images, impossible to "unsee" afterwards.
And his analysis is typically: "we´ll have to cut that d*ck"
https://my.clevelandclinic.org/health/diseases/22025-fourniers-gangrene
Physicists, including Audio guys (well, the serious ones at least) often call to help advanced French Physicist https://en.wikipedia.org/wiki/Joseph_Fourier created Math and theories, although maybe you are not referring to HIM.
He had a dismal view about Numerology, and nonsense in general.
Reactions: MrKlinky
What on earth is this thread about? 🤣
Fourier Transform can be elegant at times, can even be done in 3D, but beware the Gibbs phenomenen which introduces unwelcome infinities.
I quite like Number Theory. Read lots of books about it.
Enjoy contemplating the mysteries of the Riemann Zeta Function, which is considered the most important problem in number theory, being related to the unsolved distribution of the Prime Numbers: https://en.wikipedia.org/wiki/Particular_values_of_the_Riemann_zeta_function
It may even be that many problems in modern Physics are related to pure number! But just tantalising glimpses. Perhaps you are the person to clear these matters up!
Kepler, in one of his more deluded moments, estimated that the orbits of the planets followed the ratios of the 5 Platonic Solids. Well nearly! He later realised the orbits were ellipses. And achieved fame.
Ramanujan found the number 1729 very interesting. The Taxicab number. He was right after a fashion. He was trying to solve Fermat's Last Theorem about Pythagorean Triangles like 3,4,5.
Nobody knows why the speed of light or the value of Planck's constant or the mass of the Electron are what they are. Just a fact of Nature to present knowledge.
Most of what you have been playing with is the geometry of the famous Euclid. Pi (3.14159...) usually pops up in matters to do with circles and other round things. Phi (The Golden Ratio) which is variously 1.618 or 0.618 crops up in matters of Root 5 and Pentagons. Euler's Formula is: e^ i x Pi = -1 relating the two most famous transcendental numbers in analysis. An advance on all those stodgy old trig functions like Sin and Cos and Tan.
Einstein got bored at school. He preferred reading Euclid's Elements of Geometry to most of the curriculum. Obviously got quite good at it, His insight was to do Geometry in 4 dimensions. 😎
Yuck, Harvey Weinstein gangrene…
Fournier, as in the freqs, harmonics within the main fundamental)? ) looking At the shape of the response, in out of band (horn response) in the things I’m referring to there is a secondary layer of peak trough which doesn’t end up at -990dB (Ever hear -990 DB?? Sweet doesn’t exist it’s warm responses version of a mathematical equivalent of cancellation the highest orders of magnitude however it’s still exists) instead it shuffles in an odd number sequence related to the 864.
1.5
3
6
12
24
48
96
192
384.
the earth has 8480,12960,19440,25920 year long groups of seasons so to speak or one could describe node anti-node Function and the odd numbered sequence being winter, Where everything goes dead the same as an odd number sequence that’s out of phase in a transmission line will always leave the notch and echo so to speak at odd intervals 3.5.7.9…. The 1/4 already fulfilling .25 of 1.00 (4/4 so to speak
But 81
162
324
648
1129
2592
5184(exterior hypotenuse of the Egyptian pyramid at Giza angle) And -51.84 temperature C* when Speed of sound is speed of light.
these Are trivial coincidences that spark your attention, but the Real connection lies in the Pythagorean theorem and square roots…. Those aren’t obvious, but then the details are.
hz, sqroot/x^2
13.5(3.67423)(182.25
27(5.1961)(729)-fine structure ‘@
54(7.34869)(2916)
108(103923048)(11664)
162(127279)(26244(15 degrees)
21.6( 146969384)(46656)
324(18)(104976)(60 degres)
43.2 (.207846096)(186624)(speed of light)
540((.2323790000)(291600)
648(25455844)(419904(240 degres in V sphere)
7776
(8640)/ (.748/.75)(746496)( .250 speed of light)
9504
10368
11232
12096( .323839799) (110)
12960) (360)(1679616)
13824(7874)
27648(holding 15748)
55296(31496)
110592(62992)
1728/ (41.569219)(2.992/3)(2985984)(speed of light) holding 128q-AAaaaA
Enjoy contemplating the mysteries of the Riemann Zeta Function, which is considered the most important problem in number theory, being related to the unsilved distribution of the Prime Numbers: https://en.wikipedia.org/wiki/Particular_values_of_the_Riemann_zeta_function
If more guys like you would look at what I’m saying as well as add to it… you Are very much appreciated👍🏻
Much of what I’m saying needs to be filtered because it’s abbreviated already in order to fit into typing
We have a key set of numbers based on harmonics of 3. As bodes law Works and then the telescope figures it out in the details
(Starts at one That goes both directions around the number one.
.25/0.5/1/2/4/8
0.052083333/0.10416666/0.20833333/0.4166666/0.08333333/0.16666665/.3333/.6666/1//1.500000000./3.00000003000003/ 6.000000006/12.00000000012/24/48/96/192/384…
13824,6912,3456,1728(sqroot3) 864sqroot(0.75),432(186624),216,108,54,27(729)13.5
86.4 hz is 1meter. Thats NOT Only a standard at the speed of sound in dry air at 345.6 it’s also a standard based on the speed of light. Cause the swing of a pendulum 1 meter long is 39.37” and thats 30 degres of arc as pi/6 and
This will repeat all over again13824/13.5(1024) as 1016 does to 1/254 vs 1/250.
11264/22 is 512
11264/11 is 1024,
Everything is a wave function everything is vibrating and oscillating and everything is included in this math already including the current big bang number, the diameter of the sun, Consideration of the Hubble constant as well
64 is 13.5
32 is 27
32 is 27
16 is 54
8 is 108
4 is 216
2 is 432,
1 is 864,
1728 is 0.5,
3456 is 0.25.
6912 is 0.125
13824 is 0.0625
No matter what you do if you cycle through those numbers you come to the same type of number nearly over and over again and will represent degrees in radians or pieces of pie in degrees around the circle and it will shift around and come back again over and over in both directions if you care to type that long or just take shortcuts 0523880523No matter what you do if you cycle through those numbers you come to the same type of number nearly over and over again and will represent degrees in radians or pieces of pie in degrees around the circle and it will shift around and come back again over and over in both directions if you care to type that long or just take short cuts . To see through all kinds of dimensions including frequ endy one number app lies to everything, 0.5236 or 0.5238
‘5’ s the part of offset driver entry TL. Just like 5.25 is to ~365.25 It sneaks in little extra part every time but that fits just multiplied by four
1461/1440 (sidereal vs tropical)
365.25/360
1.01458333333
sq rt29979257759 is 173145158107
1728^2 is 2985984(Speed of light)
864^2 is 746496(1/4 speed of light)
173 parsecs too.
1000 seconds is the SOL
2AU
8.3 min(x2)
3.3 nanoseconds/meter
1 nano /foot/12 inhes..
put those two in the Pythagorean theorem and get a neck beautiful example of the location of earth and the definition of an astronomical unit to an accuracy of 2.002
02 use mikes per hour
(432)^2 is 186624
so it’s just a coicidebce At the rate is the son and the speed of light thousand miles are practically the same exact thing and so is the Oso driver entry to a transmission line anywherAt the radius of the sun and the speed of light both in miles are practically the same exact thing and so is the offset driver entry to a transmission line a
1079252849
670616629( people died and went to jail for quoting that is 666 when it was first found) its also the speed of the earth
E= mC2
C doesn’t change, just a variety of numbers used to figure things out thatrequire different units, and Unit conversions have issues. You don’t get to deny that you get to find out in a calculator all those decimal points that are missing in all of these things
Like the speed of sound is pi times 360, only one pie is associated with the meter(80/2.54) Meters associated with the speed of light in the second
The unit is atomic mass of uranium has a location of mars in kilometers and has a frequency spike at the top of the band with the 360 cm compound/series or parallel series qw pipe all share the same number.
Location of Saturn the size of Jupiter and the sun and the amount of seconds in 24 hours are all represented in the same thing precisely. They’re not a guess they’re completely relevant as a node or anti-node presure/velity.
as is almost every single number from 864 on (1728/2592/3456…)which ripples with a 24, 48,96,192 Interval alongside..
What these numbers are in mega years (25920 or 432000) Or the shorter 18.6 year wobble the earth has as well ? rotations around the Sun or time changes over great amounts…
Get archaeology look at how strange some of the numbers are and the descriptions used (it’s a little bit weird )but the numbers aren’t they are familiar once you look. Egyptian royal cubit is more accurate than radians are today.
Even relative to where we are we can still look at this because sound allows it with its numbers. Look at those numbers and nobody ever thinks to either.
14610 is 14620
(off by 10hz is leap year to hz)
but wouldn’t that be amazing if it wasn’t based on 360 instead? Phase and everything that went around circle use the same numbers as we did. We take that for granted, and we take sound and the speed of light for granted to we just blame it on that ideal gas law we don’t realize the connection between the two irregardless in the math or the numbers when the speed of light is something specific and the speed of sound in the speed of sound.
345.6m/sec The only thing that makes pie the number it is well given the 80÷254 version.
it’s a standard matter what because the speed of light is that understanding of a meter as well as a second.
Once you look into that you realize why these numbers get canceled out as frequencies in these conditions yet nothing goes out of phase or is wrong because it’s perfectly in sync with the definition of independent and swing of the speed of light from the equator to magnetic north through the primary meridian, maybe even Stonehenge?
Please things are hard to explain they don’t make necessarily sound accurate (orbtheyvseem akward) …until you look.
Thing is off by a little bit even the centimeters in your calculator can show you this when converting it to an inch look at the decimal points (the ones you can’t see) It’s not so much that they’re missing at first it’s the information that you don’t see that is important
The funnest (for now )Part of all this is it’s been discovered inside high order quarter wave speakers, when they’re perfectly aligned on top of each other from sides of the cone where they overlap and at That location.
Don’t mention that in the speaker forums though.. 🤷🏻🤷🏻🤦🏼‍♂️ Play just like this
0.5236/0.5238
In the Mathematical Universe, all things are possible. In the Physical Universe, "In which we Live in" as Beatle Paul McCartney clumsily said, certain things are just plain wrong.
The second book that Einstein enjoyed was Immanuel Kant's "Critique of Pure Reason":
https://en.wikipedia.org/wiki/Critique_of_Pure_Reason
Can you figure out what is going on just by thinking about it? Probably only if your name is Einstein IMO. And even he was prone to mistakes. 😕
In our modern age we have Large Hadron Colliders, James Webb Space Telescopes and such to inform and correct our wildest guesses.
AFAIK, the Speed of Sound is very ill-defined. It depends on atmospheric pressure, temperature, humidity and even the exact current elemental composition of the atmosphere. These things are variables. Let's not get into units. They are whatever you choose them to be. Except for the Fine Structure Constant, which is approx: 1/137 and dimensionless.
Without knowing your age, ability, educational background, or location, or how high you are on the autistic scale, it is difficult to give general advice on the way forwards.
Certainly there is much to discover. My own little obsession is Information Theory:
https://en.wikipedia.org/wiki/Information_theory
This is about what we can know. Hope it helps.
Important to note
