the speed of light and the 1/4wave speaker
My favourite speaker. OK, I could do better at a higher price:
But a lot to like:
The Wharfedale E70:
Trying to connect the dots…
Fourth model in hornresp now built that lines right up on the 860,1720, 3440 hz cancelation . In pH mode. More and more people are starting to use this and find more and more success with no phase anomalies or funky (Like in group delay in the middle of no the bluLike in group delay in the middle of A series layout(roar) ) junk in the hardest enclosures typically to build for subwoofer and for whatever reason we’re not using advanced airline anymorMore and more people are starting to use this and find more and more success with no face anomalies or funky junk in the hardest enclosures typically to build for subwoofer and for whatever reason we’re not using advanced centerline. Instead we’re concentrating on segment lengths in quadrants of the circumference of a circle. Or the concept of three to one in parallel or two into the one in Series
1 meter is 86.4hz
1 meter/2.54 is not 39.37”
its 39.37007874015748031406062992-25984251968503936(?)
as 1m, 2m, 4m, 8m, 16 m and so on are shown its own decimal points and those are ignored for some reason….
that left over we round up now and at the same time as changing former definition as the meter and a second and speed of light into a slightly different definition than the time allotted in the radioactive decay of cesium or krypton was changed. As well as the former definition which was one millionth of the radius of the earth from the equator up through Paris to the north pole. Which was assumed to be 39370 but later found to be just slightly under 40000 at ~39490 or so and humans became aware that the earth is not a perfect sphere nor were any other planets and only the sun was almost(10 km or 6.2 miles to equatorial radius difference) Yet still a pendulum at the equator when 1 m long is swung and in one second it reaches 30° Arc. That was the definition of the speed of light as you see just under 30° is 12 on 6.9375..
but That’s 0.5236 or (pi divided by six).
The calculation Einstein used using for the speed of light looked very similar to this except it ran straight out through the distance to the earth in astronomical units where he got the 29979245759 ÷ 2?? Actually you got something else but somebody documented that as whatever he got once converted to meters ?? Who knows after all most of this is also intertwining Nikola Tesla’s work as soon as I mentioned 369 over and over again it shows up deep in this math it’s all over the place but the media and government said he was a lunatic and all of his work disappeared? Care what either one of those people were as far as what’s being told to us all I care about is the truth and what’s really going on what is going on with all the stuff and why sound seems to come up with the truth when you force it from both sides of the driver together in a way that can be seen in simulation it as well cabinet design using very specific breakdown of things in different folded resonators and offset entry and exits?
What’s that got to do with anything when that’s not even been measured and it appears that it takes 499 seconds to arrive at Earth and its orbital mean anyhow not 500 seconds where the speed of light distance would be arrived in 1000 seconds or the effective diamateur of the earths orbital mean.
The point is that it’s also backed up by 345.6 m/s is the speed of sound. Because when pie is 8÷2.54 i.e. 3.1496… Times 360 it is exactly 1133.8582677 ft/sec(345.6 m/sec)??? 773.085182 miles per hr .
and if you look at the conversion for an inch to the meter as 3937 you’ll notice the same number as 039285714(22.5 * as 180/8) and 039269908 (pi/8) and Who is the dumb asWho is the dumbie Who continues to use the speed of light in a vacuum that was never measured in equations where it’s never even carried out past the third decimal point regardless leaving the strange situation where 2992 is acceptable as the speed of light it’s also hidden in (160/2.54)6.2992 and (80/254)3.1496 and (40/254)15748 and -7874 and -03937 and -19685 and -098425 and -0492125 and 0246062992,123031496..061515748,030757874015748, 01537
so I make a parallel Cordaway pipe using 80 cm or segments. There’s three on one side and one on the other….
The Pythagorean theorem says 1728 squared -864 squared is 1496. 3 and 0.1496 is 80/2.54.
but every single one of those are leaving out the decimal points that becomes more and more important…
1 meter is (39.37”)
1 mile is 1609.344 meter.
but that’s (22.5° )degrees or 3927 (1/8 pi) and 1608.4954(512 pi). (93312* ) degrees(Just have to speed of light in miles
4-3.937007874… Is 00629912…
40” is 101.6cm
30.48 is 1016 x3
0.98425” x3 is 2.95275”
3.937/4 is 3.937…
3-2.95275 is 004725
30.48 minus 30 is 0048.
0.75 is 0.25 of 3.
Pythagorean theorem is the square root of three minus square root of 75 is 1496.49188….
1728-864 =864
(1728)2 - (864)^2 is (1496.49188)^2
The speed of light is a straight line down the middle bifurcating 30° swing on a pendulum . The amount of seconds in 24 hours and 48 hours split that distance .
so twice a year the earth is located at the same exact place as it has that many seconds in epithets green theorem relationship between space and time and frequency and speed of light in waveform and quarters and halves and beyond.
