3 Phase Class D amp for DIY BLDC motor Drive
I just checked the speed/wow/flutter with a real test record and a computer program. Seems that the “yellow” ios RPM app is lying. It’s reading too high. The “blue” app is a lot closer to truth. And there’s a new app which reads decent RMS, so this table isn’t horrible. I have to find what is causing high peaks every revolution. Rms seems to be in 0.05 - 0.07 area, not bad. Most peaks hit 0.12
Here's the result of my test; not as good as my Technics SP10 mk II (0.02%), but pretty good for a belt drive
Great results. Here’s mine:
At the risk of causing a firestorm, I've seen this problem on 3 or 4 SOTA tables I've restored. It's one of the reasons I no longer will touch them. Heresy, I know.
I agree 100%. Very poor bearing design. Inverted bearing MUST oil channels bringing oil up, like Basis and old Audiomeca, from oil bath. I’ve also tried to fix this on a free with no success. But I’ve also seen a few with very low W/f figures. Go figure…
Thx to all on this thread, especially Pyramid! Build complete. I may change to pusg-buttons later.
Hi all. A minor problem (I think): when I press “start”, for the guest sending I can hear the belt slipping on pulley, until platter catches up. It’s a factory Sota pulley and belt. I remember reading somewhere in the threads, that motor should start at only 5v, preventing belt wear. I can see by the current draw that motor pulls about 800 ma at start, and after a second or two it drops to 340 ma. Is anything wrong with my build?
