Advice on Visaton configuration
I managed to take some measurements with ARTA, using a Panasonic WM61-B capsule. There is an 5dB, broad peak at around 10kHz, which I do not know what is being caused by. Any ideas?
I've attached the Arta file too.
  • measurements.zip
    measurements.zip
That is caused very likely by the characteristic response of the capsule you are using. Very similar result to the ECM 8000 microphone from Behringer. All my measurements looked like this -on all tweeters I tried- (broad peak from 3-4k to 15k then quickly falling), before I applied the ECM8000 mic.(calibration) file for the measurements.
Hi! Do anyone still have measurement files for visaton w170s, cant find any files online. Would like to test combine the visaton woofers with dayton audio Nd20fb-4😀.
For the crossover development I was using the Boxsim software, from Visaton, including the model they had provided for the W170S.
The measurements I performed were done on the finished loudspeaker, using a microphone. But these were frequency response measurements, not Thiele-Small parameter measurements.
