Class A, 4 Watt, No Feedback, Simple Circuit, Great Sound
hi, this amp is capable of driving 4ohm speaker?
With 20V and 1A bias you will only get 2W without distortion out of it so chances are you are eventually clipping it.
You could lower R5 (0R6) to 0R4 to raise bias to ~1.5A for ~4W output and thus more headroom.
Power dissipation will rise to 30W and the output stage transistors will have 10-15W on them.
You could lower the supply voltage a little (if possible) to compensate ~18V or use CRC-filters to drop some voltage.
Thanks!
If anyone is interested in some PCB's made from Prasi's gerbers to build this amp, if you pay shipping they are as good as yours. Send me a PM if interested!
I have 14 total pairs for these boards, all are from JLCPCB, HASL-Lead Free finish. 7 of the boards are green single sided, 7 are purple double sided, I've attached some pictures.
I received the boards, thanks bloqhed, and build the amp. It works, but one channel overheats. Must be some simple issue, short, or wrong part. Do not have time to deal with it right now.
Excellent news, i identified deffective output transitor (was used before, and even tested ok, still something happened to it), and all is good, both channels behave well now.
Cheers!
not much comparison yet
just listening on little test bookshelf speakers
prior to this little 4watts, I was listening to my buffer in the same setup
so I can only compare these two side by side
this 4watts classA is sweet, detailed, has great top, but lacks low end authority
ideal use for this amp is tweeter or fullrange in biamp system
my buffer sounds better, with greater depth
but I am biased 🙂
Boards arrived but build ground to a halt as I missed RZ from my BOM - a rookie error 🙄
Are cheapy ceramic caps OK for the small values as they don't seem to be in any signal path?
I also need to sort out a "test" heatsink to practice tapping some M3 holes - another skill I need to learn.
If anyone in the UK fancies building this I have spare boards I can send at cost - send me a PM.
I had the 47pF SM in stock and these are normally specified by other designers in that sort of position, they are more expensive than COG ceramic caps though. If you have something else that fits, then use that piece, if you have to buy then I would use SM.
Reactions: IanA
I did my first attempt at the easyeda.com online site as I do not have kicad or other softwares 🙂
Here is a small renderer and I did print few boards to test my board and I tried to use small caps of 2200-4700/35-50v low noise and also they are cheaper than bigger sized caps. Hopefully it works, if you are interested here are the gerber files.
Note: This board is yet to be tested.
I can confirm that the boards are working fine with a test rcore transformer I checked with the 23VAC rail I get a stable 34.2vdc because of my home voltage being a bit higher than the normal 220vac. Here are some of the pics using Samwha 4700/50v caps and pair of BPR 0.33R/5W resistors.
I've made some progress. Drilled and tapped the heatsink and attached to bench PSU. Unfortunately the current draw is only 20-30mA (shown on bench PSU) whatever I do with the pot and seem unable to bias the circuit.
Could anyone point me in the right direction for troubleshooting and what measurements to take? (this is my first build so patience is appreciated)
Many thanks
Many thanks
I'm not entirely sure if it applies to your situation, but I recall in post #139 it was mentioned that the output cap can't be hanging and you need to load the speaker output by tying a 100R/2w resistor from output to ground.
Reactions: IanA
