Things went off track at post #91.
Did you test the output side FETs?
Did any of them read different from the others?
None of them were shorted all were close same readingsThings went off track at post #91.
Find the end of C2091 that's connected to ground.
Connect a jumper from pin 8 of U2000 to the ground end of C2091.
Will the amp power up with the B+ connected?
Yes, with it jumped.
Yes. powering it up normally.
I wanted to make sure pin 8 was grounded.
Do you see a pulse of DC on the speaker output as you power the amp up? You'll need to be watching the scope from before applying remote. Then for 5 seconds after.
With it still jumped? And am I suppose to
Sorry obvious questions. There is 0.14v on pin 8 of u2000With it still jumped? And am I suppose to be powering remote as well? I hope so. 1.1mv
DISREGARD THIS POST ..This is with it not jumped...
Does it still go into protect with pin 8 grounded?
If you connect a load across the speaker terminals, does that bring it down to 0v?
Yes protect with pin 8 grounded. yes voltage goes to 0 with load.Does it still go into protect with pin 8 grounded?
Why when I put voltage to pin 2 of u101 does it power? ,is that bad to do?
It happend by accident when I shorted pin 2 and 3 of u101 with probe.
Just a video of what it's doing.
Videos are generally useless for repair work.
What's the PS driver board number in this amp? It likely starts with 1405-...
I want their marked value. Measuring the resistance with the parts in the board could be reading other parts as well.
- General Interest
- Car Audio
- RF T2500.1BD
