Foil vs electrolytic capacitors for tube amplifier power supplies
Hi
I am not sure if this is the right place to ask this. Feel free to point me to the best forum category. Electrolytic capacitors are mainly used because they are cheaper and smaller and they can hold a much higher capacitance.
My amplifier uses 3x 220uF 450V capacitors for the power supply. I am looking to do some upgrades and I never looked at foil capacitors for those values because I thought they don't exist. However, they do actually exist.
Would there by any benefit in using foil capacitors over electrolytics for power supplies and cathode bypass? Provided there is enough space and they have the necessary capacitance and voltage.
I'd love to hear your opinion
Absolutely no advantage with the exception of a CLC type 5U4 or GZ34 rectifier. The cathode of the rectifier feeds the first capacitor known as the tank capacitor, usually between 4 and 8uF oil type. This then feeds the second capacitor through the choke. A 47uF electrolytic will smooth out the DC power. Any lumps or bumps are smoothed out by the reactance between the choke and feed capacitor.
Otherwise with silicon diodes, use what you like in electrolytic form. Bearing in mind the current draw from the transformer trying to fill up the tank capacitor. I have seen many transformer fail due to the value being too large.
Absolutely no advantage with the exception of a CLC type 5U4 or GZ34 rectifier. The cathode of the rectifier feeds the first capacitor known as the tank capacitor, usually between 4 and 8uF oil type. This then feeds the second capacitor through the choke. A 47uF electrolytic will smooth out the DC power. Any lumps or bumps are smoothed out by the reactance between the choke and feed capacitor....
Interesting. I've got a World Audio Designs WAD6550 push pull kit. It has 5U4 rectifiers and CLC filtering (50uF/2.5H/50uF). The kit came with 100uF electrolytic caps used in series with balancing resisters. I managed to replace those caps with 47uF oil type caps. Foolishly, I replaced the coupling caps with PIO's at the same time, so it is hard to say what the sonic difference was. (I replaced the PIO coupling caps with plastic caps later, which I actually found to prefer.)
What value too large?
In our SE builds we found that using polys in the power supply made a huge improvement. Since then we have not done any with elcos.
dave
Yes. Allen Wright’s PP amp uses 4 (at least that big), they are in the towers.
Ah nice thanks for all your answers, I learned quite a bit - I hope others did aswell.
I have one last question if you don't mind. Is it worth spending a bit more for a higer-end poly capacitor for the RC Filter? Would the difference be negligible between, let's say a Solen PPE FastCap and a ClarityCap CSA which costs 3x as much?
I use poly caps in my SE amp too. They seem to lower the noise floor and have lower ESR that gives faster power delivery and tighter bass. I found Apex Jr on the auction site has cheap 75uf 600v poly caps for like $5 each that work really well. If you use a tube rectifier you need sub 50uf cap right after the tube. They are bigger than the electrolytic caps but they end up being more convenient as you only need one as opposed to two in series for voltages over 450v like most common electrolytics. They last forever as a bonus. I see no down side.
What makes that only with "a CLC type 5U4 or GZ34 rectifier" there is an advantage in using a capacitor other than an electrolytic, while in every other situation there is "absolutely no advantage"? What is so special about the 5U4 or GZ34 in combination with CLC that this would be true?
Nothing, that was just an example. EZ81, 5Y3 etc etc are similar but the GZ34 can stand a higher capacitance on the cathode than say a 5Y3 or GZ37 or U54 as the latter can only use a 4uF tank capacitor. Have a look at the valve data sheets.
OK, now you are changing your statement from "Absolutely no advantage with the exception of a CLC type 5U4 or GZ34 rectifier." to something like: "Absolutely no advantage with the exception of many exceptions".
This thread is not about the value of the (first) capacitor in power supplies but about the question if foil capacitors have benefits over electrolytic capacitors in certain applications, like power supplies. So why should I have a look at the valve datasheets? I never saw a datasheet for a valve rectifier that stated something about possible (dis)advantages of certain types of capacitors.
If they are magical, as many seem to thing, why didn't Quad, Leak and many more renown HiFi designer incorporate them in their designs I wonder.
A good quality electrolytic or two and decent mains borne interference reduction, is all that is required.
No HiFi designer will ever put the most expensive capacitors and components in general a circuit tbh. Find me one amplifier that stock uses OCC copper wires $70 capacitors, Audio Note non-magnetic silver Nobium resistors which cost $40 each. Or 4oz copper PCB, heck you can even go higher but then you pay $500 for a PCB.
Also reasonably priced high capacitance foil capacitors is a new thing. A 220uF 450V electrolytic costs $10 a foil will be $60.
My amplifier has a rectifier and it doesn't have a tank capacitor.
It has 2x 22uF 500V RC filter
2x 0.22uf 450V signal
2x 220uF 16V cathode bypass
3x 220uF 450V power supply.
It has no capacitors after the rectifier. The 3 PSU caps are directly in front.
