Phase Research Loudspeaker - Polydax/Audax inside; which currently Brand Name ?
any news?
Hi from Germany,
I am thankful for the multItude of infos i could grab here from this threat. Especially for the link to the Audax Speaker.
I would like to substitute also my bass speaker. Do you have any idea where and how I could manage this? Sorry to take this way for a contact, but i can't see any chance for a PM here. I also tried to get some Infos through the german Hifi Forum.
Would be nice to get some help from you. best regards Frank
Hi from Germany,
What is the reason therefore ? damaged resp. burned voice coil ? or is only a re-foam (new surround) necessary ?
I think, there is the only possibility of repair/refurbishing of the old one and no possibility for a replacement bass driver with the same parameter and sonic characteristic.
ask there for both cases:
http://www.ppa-audio.de
https://www.klangmeister.de
https://www.lautsprecher-manufaktur.de
http://www.rmjloudspeakers.com/contactus.html
http://www.recones.com/pricelist.pdf
https://www.swrfernsehen.de/die-scheune/folge-5-104.html
Concerning the brand name "POLYDAX" some information are here:
https://audiokarma.org/forums/index.php?threads/anybody-have-an-opinion-on-polydax-speaks.61202/
I did not know they made any speakers. I knew of them by being a fan of Bob Carver beginning in 1980s. Phase Linear was, I think, his first company, or at least he was employed there. PL were known for their amps and other electronics, but a speaker is news to me.
Blast from the past! Those were my Phase Research Model Rs with the auto sound woofers. What a funny surprise. 😀
My uncle purchased them in the late 70s and gave them to me much later. He put those woofers in them. I used them in my college dorm rooms in the 90s, moved them to FL and back in the early 2000s, and discarded them over 10 years ago. I think that picture was from my basement in a previous house around 2007. I recall the tweeters were something special and the bass was surprising. Those Rockford fosgate woofers were not very good in the mids. Built-in smiley face response! 😀
Phil Clements and Phase Research had nothing to do with Bob Carver or Phase Linear, if I recall correctly. Just similar buzzwords.
Reactions: 6thplanet
I thi......
nice to get a reply, cool!
Actually I have no clue what it could be.I testet the bass speaker with and without the electronic platine and everytime on a certain higher volume it starts to give cracky noises. on a low level it seems working well / better.
i got the foam changed some 10 years ago, they were partly "fallen apart" , but this time they seems to be okay. ( btw. it's just one box with problems. the other plays fine.)
How could i test it?
Best regards
Frank
Best regards
Frank
You have test the bass-chassis in question on the other amplifier-channel ?
If the described unwanted effect is still present on the same bass driver please dismounted it and mount it rotated 180 degrees - maybe the weight of diaphragm has minimally deformed the suspension over the years and the voice coil is no longer exact in the center.
If the described unwanted effect is still present on the same bass driver please dismounted it and mount it rotated 180 degrees - maybe the weight of diaphragm has minimally deformed the suspension over the years and the voice coil is no longer exact in the center (sometimes I had observe this on B&W's CDM-1).
@ tiefbassubertr
thanks for this advice. A friend of mine mentioned this as well. Speakers can loose their center and deform resulting in an inadequate sound.
After changing the channel I will follow your advice and rotate the speaker clockwise up to 180 degrees.
Is this repairable? Meaning, get it centered again? Or in worst case it's a total damage? seems that i get the change to buy another bass from PR next Thuesday ( but for a couple of hundreds) .-(
Naturally I would like to avoid that scenario ;-)
It's actually unbelievable to get so much input here and on other places about an rare 'orchid' as PR ! I mean, how often had they sold it then? 1000 pcs 10000 ?
Amazing moments in Internet! Thanks you and all the others.
Sincerely yours
Frank
I am looking for a pair new dust cover (foam covering) for this loudspeaker.
There are a wide range of such materials available, but how can I find out, what is the best suited for this application?
Maybe this?
MyCaseBuilder - How to Choose the Right Custom Foam
Also I'm looking for material for sound insulation on the baffle, which also consists of a kind of foam.
About
Phase Research Phase-R‚ÌŽd—l ƒtƒFƒCƒYƒŠƒT�[ƒ/ƒtƒF�[ƒYƒŠƒT�[ƒ
you will see, what I mean.
Thanks for advices.
this company is the right contact address therefore - unfortunately his website is dead since approximately two years, but on webarchive still available:
https://web.archive.org/web/20160314095609/http://foamspeakergrilles.com/P.O. (Box 746 Evart, MI 49631)
https://web.archive.org/web/20210410142814/http://foamspeakergrilles.com/ (Box 93 stanwood, MI 49346)
maybe the same guy now on ebay (not absolutely sure):
https://www.ebay.com/itm/186090243657
https://www.ebay.com/itm/285421643680
https://www.ebay.com/itm/186045247158
an image as example I have upload here (first both attachments) - found under
https://www.hometheaterforum.com/co...speaker-company-called-phase-research.168036/
Are such suppliers are also in Europe ?
Thanks for an advice.
P.S.: several PDF files in the attachment - already present in one of the previous posts - but here in higher resolution
