can speaker impedance be calculated
Yes i understood that but thought the mid driver is only affected by the 1.5mH inductor and the woofer driver is affected by the combined total inductance of the two inductors making both filters 1st order. What am i missing?
In your case, I would suggest an impedance correction on each driver of approximately 7.5R and 15uF.
Middling case for a Kevlar driver. Not far off this SEAS CA18RLY paper driver.
http://www.seas.no/index.php?option...8rly&catid=44:utv-prestige-woofers&Itemid=461
This will lead to an entirely different circuit to B&W P6 2.5 way speaker. I don't want to go into it.
https://www.diyaudio.com/community/threads/flat-impedance-and-flat-power-response-design.302001/
Then add some optimal calculations. Thus.
would results be meaningful
No. Well, what are you trying to find out and why? What do you want to do? I applaud your striving for knowledge, that's how I got sucked into becoming a loudspeaker engineer. It is down a rabbit hole, the more you learn the more you realize "oh it is more complicated than what I thought!"
As mentioned before, impedance is complex, and more complex than assumed in the early days of Thiele-Small modeling. Those labels "4 ohms" or "8 ohms" or whatever are the most oversimplified model, and often lied about these days (makers will put "8 ohms" to something that is really more like 4 because they don't want customers to say "oh I can't buy that my receiver is only 8 ohms"). You can see a typical curve for a woofer here https://audiojudgement.com/speaker-impedance-curve-explained/
  • At the lowest frequencies, the impedance is dominated by the DC resistance of the voice coil, which is what your ohmmeter would measure presuming the driver is not connected to anything. (In other words you have to disconnect the crossover).
  • As you move up in frequency goes up up up until you come to a peak which is the resonance of the driver, the impedance goes down down down until a flat part somewhat higher than the DC resistance.
  • Eventually the impedance goes back up. This is NOT because the voice coil is like and inductor. That is kinda true but eddy currents in the magnetic pole pieces also. Usually you get a "semi-inductive" rise. When you see "inductance....XX mH" on a spec sheet that is usually at 1 kHz or something. It varies with frequency.
This same general shape holds true for most any cone driver. Sometimes there are wrinkles due to reflections. A sealed box follows this shape; a ported box will have two low frequency peaks. Horns and waveguides can have a lot of kinks and wrinkles in the impedance. All of this is WITHOUT CROSSOVERS which introduce more variation.
Reactions: TNT
This is a great forum and the very knowledgeable members have helped me learn some basic XO design considerations. As I learn more I'm sure there will be more questions. Basically I thought the woofer filter is 1st order because there are only two inductors in series, with no other components, and they are equivalent to one 6.5mH inductor.
Thanks. In your post 26 attachment I saw it was labled 2nd order and thought that was due to the resistors. So I think I now understand that any filter with two components is 2nd order. I thought that replacing two inductors with one inductor, equaling the combined value of L1 and L2, would result in an equivalent 1st order filter.
I really don't understand you reply. I know the woofer frequency is about 30 to 150Hz, mid range is 150 to 3000 Hz and tweeter is 3000 to 20kHz
May I ask you to make a graph of this design, with frequency on the horizontal axis and sound pressure level at 1m distance from the front of the speaker on the vertical axis? And if you have done so, would you please explain why you drew the lines like you did?
