Zen Acousta
Founder of XSA-Labs
Joined 2012
xrk971
got it, will try it on my Zen acousta 2.
Did you ever make Zen Acousta 2 with the mods we discussed 6 years ago?
If you add an 8 liter volume x 6 in deep driver chamber connected to the main horn (at same location) with a 2.5 in dia hole through 0.5 in thick plywood that connects the chamber to the horn, you can extend the bass down by about 10Hz and smooth out the response somewhat. This is with Alpair 12.3P. I think the Alpair will be less bright and more balanced than Lowther, and less expensive too
And made this:)
Hi
Thank for suggestion, I'm using cotton rope now, will try rubber bands.
Swing at very low cycles....2-3 Hz!!!Absolutely good suggestion as my turntable sling setup.
The reason why the wooden disk outside, because of the front loading horn.
Hi!
KoHo,can you please give plans for front loaded horn?
I have Dallas II with Fostex FE206EN and i would like tu upgrade them with front horn,to gige them liglle juice to the midlle range.
No,i still didnt install them,but its a plan to do so.
You think its better to start with phase plugs and see what will be?
Now after some time of listening dallas,im lacking cleariti in mid range. High mid i would say.
In few week i get pair of Raven 2 ribbons so i will put them inside Dallas instead of monocor bullet wich i have now.
