Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
it'll be as usual with my concoctions, in two levels
first - just pcb with smd critters soldered on, so basically most critical parts; rest can be bought in nearest Grocery Store
second - full Monty, pcb with all parts (sans outputs), and "all parts" means - you choose which of 3 iterations you are going to build/try first
Don't worry about that, I can solder the little critters myself no problem
it will get annoying from 0402 and smaller though :D
Viking greetings
