DIYA store "Wolverine" (Son of Badger) .... suggestions ??
Reactions: 1 user
If you will use a very thin screwdriver you will not have a problem adjusting the deflection voltage.
Another solution is to use ,a piece of fiber glass or something similar,underside the trimer to rise this s little.
Reactions: 1 user
If the PCB is mounted parallel to the heatsink you may want to mount the trim pots facing the other way, so you can do adjustments from the top. Obviously, for adjustments, you will turn the trim pot in the opposite direction....
If you have a very large chassis you may use top adjust trim pots, if you like.
Many options, pick a solution that suits your needs.
Joined 2016
Hi guy's,
Just a quick update on Thimios's progress. He has completed the build of the amplifier PCB except for installing the output transistors.
He is in the process of drill and mounting the pcb on a heatsink.
Thanks for your efforts on this project Thimios.
Reactions: 1 users
Joined 2016
Hi Stuart, my picture above showed.
It is not standard heatsink, so how large of size should be used?
As I said its the CCS2 and VAS Heatsink and is 50mm x 30mm x 1.2mm (Minimum)
You need to make it yourself. Dimension and hole locations will be shown in the comprehensive build guide currently 34 pages.
And what the purpose of screw contact on the heatsink?
To ground the heatsink to prevent any tray parasitic capacitance from building up and affecting the transistors or surrounding components. Grounding the heatsink provides a easy path back to ground for any capacitively coupled EMI etc.
This flat plane heatsink does not contact to the transistors?
This depends on the transistors used whether you need an insulator pad or Kapton tape. But at the end of the day both transistors need to be electrically isolated from making contact with the Heatsink.
Joined 2016
Hi Guy's,
Just a update from Thimios.
He has done a great job finishing off the assembly of the EF3-4 pair ready for testing.
Please note that the heatsink that Thimios has used is just for testing purposes. The heatsink was just one that he had on hand.
Reactions: 2 users
