ESP P3A
Been working on a stereo PCB based on the Project 3A from Rod Elliot, i'm here asking you guys what do you think about this layout.
P.S. Since i can't find the exact BJTs used in the original Project, i wonder if i could use a couple of 2SC5200 and 2SA193.
The drivers/VAS are not positioned correctly. Maybe you could start by reading Rod's indications concerning their placement and/or purchase his PCB.
The routing seems excessively intricate for a relatively simple circuit: Rod's layout is much simpler and single face. I used 2SC5200 & 2SA1943 in my P3A.
There are many threads here about attempts to design and make DIY P3A PCBs to save a few dollars. Most so far, have been pretty poorly conceived and many designers seem to misunderstand the basics of good layout, even to the location of a driver transistor that needs to be in thermal contact with the bias control element Q9 (the Vbe multiplier transistor)
The threads are easily searched with our new forum software and though there are plenty of efforts that should be avoided, Alex MM's professional design appears to be among the best, though I haven't personally built or tested it. There's no need to re-invent the wheel here, just use the valuable info and resources already examined, proven (or amended if there are errors) and made available here.
I've already drawn the original Layout:
