Is the SAA7220P/B really that bad ?
Hello
The CD650 CD-player, who use a SAA7220 and a TDA1541, did use a 3k9 pull-up resistor BCK to +5V
Seem interesting, anybody try a pull-up resistor like this one ?
Thank
Bye
Gaetan
Hope you get an answer, looking for the right way to feed from a flipflop w or w/o the R in the line, so a can it be fed by a 5V clock directly or may I keep the RC wich is between the SAA7220 fed...
I still have that in mind:
... the 7220 swings 5v pk-pk on its outputs, and the 1541 only needs a tiny current centred c1.4v to switch - it's a current-routing logic; the excess voltage swing just pushes HF currents into the dac.
From memory its not that high, I seem to recall from my study 0x20. But it depends on the suffix letter of the SAA7220, I think I tested the B suffix.
Oh, That's awesome. Thanks for your memory.
I thought it must be one of the unknown reasons for its sound characteristics. Because It decreases the chance of Zero-Cross distortion. :magnify:
Found some diagrams on the Chinese forum:
SAA7372 at 16.9MHz: but I thought, pin25 WCKO of PMD100 can be connected directly to LE of the TDA1541A...?
This is for the I2S output of the SAA7310: but shouldn't pin14 be tied HIGH...?
Glue logic for SM5813: again WCKO could directly be connected to LE, but the forum member wanted to match the timing requirements of the TDA...
Links to original forum posts: here and here and here.
