Amp Camp Pre+Headphone Amp - ACP+
Hi, would be thankful for help. I have no sound on one channel. I hooked up the ACP plus with a laptop charger at 19vdc. The working channel measure 9,5 vdc but non working channel measure 16,5 at dc1 and the heatsinks are cold. Could it be faulty q5 or q6?
Thanks in advance
Is R4 125 Ohm?
Regardless of the value, it needs to be lower to suit the J113 that you have. The J113 is working as a constant current source and its source resistor, R4, needs to be adjusted so that (voltage drop across R4)/(value of R4) = 0.010A
Will the ACP drive small 8ohm bookshelf loudspeakers (Sony SS-5GX)? I already have the PCB but have put-off spending on the parts. I don't really need the Adcom 545II that used to power my grand system - now gone. Nor do wish to spend on a smaller but still bulky power amp.
I rarely have my passive volume control (Schiit SYS) as high as nine O-clock using the Adcom amp. And that is as 'loud' as I dare lest I annoy my downstairs neighbor again. 🙂
Another ACP+ Is alive in Hammond case. LED is muttering “almost there…”
1V in, 5.8VPP out. Driving F4 nicely.
PSU is 24V.
thd 0.08-0.12% RCA out
9.8mA through R4 (47R)
Sounds wonderful with 32ohm headphones.
