TPA3255 - all about DIY, Discussion, Design etc
It is a nice amp too, I own it see below )) Do the accounts:
$176 for the module
$70 for a clean PSU
$80 for a neat case
$25 for plugs / wires
$15 for drilling
Total : at the very least $386 including shipment
Checkout now :
JL ELectronics Sylph-D200 Amplifier Module Review | Audio Science Review (ASR) Forum
Topping PA5 Review (Amplifier) | Audio Science Review (ASR) Forum
Topping PA5
Jlester TPA3255
Hello,
I always read your post carefully.
The Jlester SYLPH-D200 has a gain of only 14dB, but do you feel dissatisfied with actual use?
Topping PA5 has a gain of 19dB, but when using it, I sometimes feel that this value is a little low.
Toku
Hi amigos,
Just to share, a new full balanced TPA3255 is now avalaibe with a motorized volume knob and DIP8 op amps, will share my impression as soon as I get it )
had some free days beetween turn of the year and finally build the 3e audio TPA3255-2CH-260W (first version)
I tried adding a ALPS 100KA Stereo LOG Potentiometer but the board eventually give me a Fault every time i tried it
without the pot it working fine did I choose a wrong value for the pot?
I just need a "passive" input volume control for the line in to make sure the connect AUX (either macbook or express port or other devices my son will use)
Any help or ideas would be great
Her goes sorry :
https://fr.aliexpress.com/item/1005003702029950.html?spm=a2g0o.cart.0.0.77f33c006PWkUY&mp=1
I was wondering if it came with a remote control? answer from manufacturer : NO but :
"Motor-driven volume potentiometer" any interest without a remote control ? hummmmm....
This one has a remote control with bluetooth, but didn't balanced and no internal photo, but cheaper..
US $85.50 18%OFF | BRZHIFI Audio Bluetooth 5.0 300Wx2 Power Amplifier 2.0 Amplificador TPA3255 Digital Sound Amplifier USB RCA DAC Amp Home Theater
https://a.aliexpress.com/_mNidEgM
Hi! I'm from Hungary, and I'm thinking buying a Shui Yuan Audio TPA3255 panel. I'd like modify a little bit (capacitor change, maybe opamp and inductor change to better). What is your opinion, can I reach with these modifications the more expensive board's sonic quality, or worth buying the expensive boards without mods?
I'd like use this SMPS: https://www.aliexpress.com/item/323...1;27.43;-1;-1@salePrice;USD;search-mainSearch
Opinion?
Thanks for help!
Opinion?
Thanks for help!
This power supply is just good for powering LEDs ...
All my TPAs worked best with a linear power supply.
Or Menwell or mornsun. 🙂
It's the same as on the audiphonics site ....
https://www.audiophonics.fr/fr/ampl...5-bluetooth-50-2x-85w-4-ohm-noir-p-15546.htmlI go my way ... My little Merus Ma surprises me
every day.🙂🙂🙂🙂
I agree, I put it on for the others, me too it's Merus.
Opinion?
Thanks for help!
I have the Shui Yuan Audio TPA3255 PCB and I changed the 2 big power condos as well as the OPs by OPA1656, frankly don't waste time with this PCB and go directly to the more expensive ones without modifications. Unless you are not looking for anything too musical, or to put in a garage ( JLE or others, not 3EAUDIO... Topping PA5s).
for hc, it is suitable ...
But here it is (for my part), we are always looking for better!
I look forward to the MA chip ....
https://www.infineon.com/cms/en/pro...egrated-class-d-audio-amplifier-ics/ma5332ms/
I know amigos )
This is one is not full balanced..... the one I shared is the only TPA3255 amp with balanced inputs under $200. And it should be very nice for DIY )
Opinion?
Thanks for help!
The PSU is not so bad, I used it for many projets. I have the Meanwell and another LLC PSU as well. I am also using a linear PSU in my TPA325X projects.
Th Meanwell has the best ripple but the shared PSU holds up and works very well in most of my projects
You can do your own Linear PSU with a 4x 10000µF 50V Audio Nover caps :
Power module Nover Caps
Hello,
Toku
14 dB gain is quite low, but it's a function of losing gain to enable the passive PFBB. As far as I understand it, the decision was made not to restore the gain in order to "optimize" (some would say "game") the noise performance. You will need a DAC with high voltage output or a pre-amp to fully utilize the Sylph's maximum power.
I know amigos )
Hi Daniboun, I wrote that it was not balanced.
And for half the price. can be okay on a tight budget. In addition there is a remote control, much better than a motor that is useless. Is not it. Me personally I would not buy this amp, would be ready for the one you show, but maybe practical.
The left module is an AC Audio grade filter.
Checkout the 3E Audio now we are far away from the PA5 )
average amp TPA3255....
I'll let you guess what is the best price / performance ratio
Very unfair to compare the test results of the 3e-Audio integrated amplifier that uses a DSP at the front end with a TPA3255 Board with no DSP. The lower SINAD and TDH is almost all due to the DSP used. You also have the other 3e-Audio TPA3255 boards which would be a far better comparison.
