Rockford Fosgate T2500-1bd
Got this amp in the guy said he touched the rca shield ground of the amp to the power wire by accident .
The amp still comes on and plays but has noise and pops through the subwoofers . He already changed head units but the amp still has the issue .
Any ideas on where to start ? Nothing looks burnt and everything I’ve checked so far tests good
I can’t get the test speaker to pop on the bench . On The bench the transformer wines and the amp draws about 20 amps of current
The amp uses different FET gate resistors for the two sets of FETs. The one that's heating uses the higher value FETs for both banks. In some instances, replacing the 60.4 ohm resistors with the 47.5 ohm will solve the problem. If nothing else, it will tell you if the problem is elsewhere.
The transformer that had all 60.4 ohm resistors Is the one I’m referring to . The fets still get warm and the transformer wines like crazy still
But the idle current right now is about 4 amps . Here is what I get for the drive signal on those fets .
scope set to 10us 5volts/Div
