MiniDSP 4x10
Bought a new MiniDSP 4x10, will use it for a 2x3-way project.
Before connecting to my amplifier I measured output resistance, to check my new cables.
On all channels, except channel 4, I measure about 10kOhm, on channel 4 the value was >30kOhm.
Same values on RCA outputs.
I contacted support: "All units are QC 5times so I think that your 4x10 is all fine. No worries. 🙂 "
Should I be worried?
Anyone with a 4x10? Can you measure your values?
There are no minidsp schematics I have ever seen. Since they use multilayer boards its a PITA to trace them out and sketch up a schematic. However, did manage to trace out some subsystems on two of their boards. Seem likely something like that would be necessary to get to the bottom of why channels measure differently. From the perspective of minidsp the unit is probably fine if it meets or exceeds their published specs.
My 4x10 also shows a higher value of DC resistance on channel 4 (powered on - no input signals) but, while this is interesting, a DC resistance test on the outputs of what I assume are AC coupled outputs is not going to yield useful measurements. Now my curiosity is piqued; it may be that leakage paths on this channel are lower. Hmmm...
Interesting, something with the design then, and nothing special with my unit. Feel better now. 🙂
I'am not interested in the output impedance. Just measured to verify my cables, and surprised that one out of 8 channels has a different design.
Thank you everyone for clarifying!
No, one channel does not have a different design. All eight channels are identical.
If your DVM revealed a different measurement, it's because you had a bleed charge in the output capacitors and/or some other variable.
You CAN'T measure output resistance (reliably) with a DVM. I'm not sure why this concept is seemingly so difficult to accept.
Dave.
Yes, it is the wrong way to go about measuring impedance. I am an electrical engineer in product design and I stand by the evidence that channel 4 output resistance is different from the others, however it is almost certainly inconsequential to the performance of the device. It is merely interesting.
I opened my box and do in fact see that two resistor pairs for channel 4 are 51k (513 code, and as measured with my meter), while all the other channel pairs that are in the same relative positions are 10k 1% (01C code). These are resistors near the balanced output section. Now we know what, but not why.
Nice work.
Would be interesting to know why the design of channel 4 is different.
I will out of curiosity send the question to the support ...
