Yes, it should work fine. Maybe a higher voltage rating would improve its long-term reliability a bit, but film capacitors are usually pretty reliable anyway (except those connected straight to the mains, but that's another topic altogether).
How do you keep the input voltage in the correct range (about 15.8 V to 20 V, assuming 1 % set resistor tolerance)? With a preregulator?
You need to set up the voltage divider such that taking into account all tolerances, the voltage at PGFB is above 309 mV when the output has settled. 150 kohm and 3 kohm would therefore not work, 150 kohm and 3.3 kohm should work when you use accurate resistors, 150 kohm and 3.9 kohm should work when the resistors are not that accurate. With 150 kohm and 3.9 kohm, it would typically fast charge up to 300 mV * (150 kohm + 3.9 kohm)/3.9 kohm ~= 11.8385 V and then settle slowly from there.Can some one explain me how the fast startup work ?
Does it mean that when the PGFB pin hits 0.3V it will disable disable the 'fast charging' ?
I set the 3042 at 15v. so i have spare of cset 150k resistor i want to use to set Fast startup.
If I use 150k + 50k divider it means I am dumping a 75% of the output voltage (since the voltage divider is connected to Vout pin), so it will hit 0.3v at the PGFB pin (and stop fast charging) when the Vout pin is at 1.2V. Or does it mean I have set up fast charging at 75% ?
0.3v is 2% of 15v. if i want to set the PGFB pin to be at 0.3V when I hit 15Vout, I need 150k+3K voltage divider ?
Thank you.How do you keep the input voltage in the correct range (about 15.8 V to 20 V, assuming 1 % set resistor tolerance)? With a preregulator?
No, I was planning on keeping it simple, a single center tapped secondary of 24VAC (30*1.33=39Vrms), a single bridge rectifier, 2 CRC filter (1 for the negative rail to the lt3094) like this :
https://electroschematics.com/wp-content/uploads/2010/12/12-VOLT-DUAL-POWER-SUPPLY.jpgOr maybe should I use 2 bridge rectifiers like this :
https://www.diyaudio.com/archive/bl...1498953002-dual-bridge-rectifier-pcb-dbrb.png
Having 2 bridge rectifiers is the superior method, probably less ripple ?
I did not plan on adding pre regulators, Do you recommend pre regulator ? the load will be pretty light a dual opamp in a single package.
If you are using 1% resistors there is no problem in running the fast-startup closer to the desired output voltage. In this case 150k & 3k3 resistor should be fine. Or even 3k16.
For Cset of 22uF film capacitor is total overkill. Tantalum works fine here even with 16V rating.
You need something like 15.8 V to keep the regulator out of dropout and the maximum recommended input voltage for the LT3045 is 20 V. With +/- 10 % mains voltage tolerance and with the ripple voltage that you will get, I don't see how you can keep it in such a narrow range without some preregulator. You could for example use a run-of-the-mill 18 V LDO to protect the LT3045 against too high input voltages. It doesn't matter when the 18 V LDO goes into dropout at low mains voltages, just as long as the momentary input voltage of the LT3045 stays well above 15.8 V.Thank you.
Thank you, so it will be better. Will it also lower the noise a bit ?You need something like 15.8 V to keep the regulator out of dropout and the maximum recommended input voltage for the LT3045 is 20 V. With +/- 10 % mains voltage tolerance and with the ripple voltage that you will get, I don't see how you can keep it in such a narrow range without some preregulator. You could for example use a run-of-the-mill 18 V LDO to protect the LT3045 against too high input voltages. It doesn't matter when the 18 V LDO goes into dropout at low mains voltages, just as long as the momentary input voltage of the LT3045 stays well above 15.8 V.
What is the best pre regulator I can use before the 3042. Do you know if there is a schematic on this post or else where ?
I am a bit affraid of the pcb design tho now with all these parts but tha is how you learn.
Hey I want to thank you a lot for your help guys, I really appreciate everything you do.
I use 1% 25ppm, Thank you. I will buy a tantalum it is cheaper at higher voltage rating. Thank you for the help.If you are using 1% resistors there is no problem in running the fast-startup closer to the desired output voltage. In this case 150k & 3k3 resistor should be fine. Or even 3k16.
An LM2941 could be used as an 18 V preregulator. The maximum input voltage is then 26 V, the minimum to keep the LT3045 out of dropout would be about 16.8 V. See https://www.ti.com/lit/ds/symlink/lm2941c.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&DCM=yes&ref_url=https://br.mouser.com/&distId=26 You can probably get the voltage in the 16.8 V to 26 V range with a 15 V transformer, rectifier and capacitor.
Thank you. I kind of understood about the 1.5v for lower noise and the 0.26v for the dropout, means 16.76v min. Thank you so much for you care.
Can I ask you if it will be good enough as a preregulator ? I can buy more expensive parts as I am only building it for myself.
I dont really care about the cost of the preregulator, but I dont want to pay too much if it will not bring any improvement. My main concern is to not add noise, or even better, lower it even more with a preregulator.
I you had to choose the best pre regulator (best for the task, not the best on the market) which one you would choose ?
Hi, was going to order the LM2941 (it is fine LDO thank you for the recommendation) but for the negative rail I would like to avoid the lm2991, from a simple research on diyaudio it seems it is a very bad regulator, it is noisy and its psrr is sub par from what I read it's noise is also in the 200 to 450uV in real life it seems :
https://www.diyaudio.com/community/threads/simple-linear-crcrc-psu.353363/page-2#post-6304334
see this also :
Is there another combo I can use ? LT3080 maybe and its negative equivalent (but it 6euros vs 2.5euros for the lm2941).
Thank you.
see this also :
The negative version LM2991 is a famous one, it has a typical noise figure of 200 µv and a maximum of 450 µV!!!!!!! You should don't even want to use those.
I suggest people that need a good symmetric PSU look here:
VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser"
Thank you.
Noise of LM2941 is 0,003% of output voltage. Maybe you should calculate how much that is at e.g. 15V compared to 450uV.
lm2941(positive) is fine, it seems the lm2991(negative) is problematic ? I am building a dual supply.
On the quoted post Jean Paul said :
'please reread on LM2991. You can almost not choose a worse regulator for audio. Even 79xx is way better than that.'
Please calculate how much 0,003% is at 15V. Then compare this figure to max 450uV noise of LM2991. Then see if either one is problematic.
The LT3094 that you want to use for the negative rail has a noise of 0.8 uV RMS from 10 Hz to 100 kHz and a PSRR of more than 75 dB. That means that as long as the noise of the preregulator is well below 4.5 mV RMS, it won't dominate the noise at the LT3094 output, so 450 uV should do fine.
Yes, as a pre-regulator LM2991 is just fine. I don't know if Jean-Paul did the calculation but 450uV sure does sound much bigger than 0,003% of Vout 😉
Also note that similar noise specification (0,003% of Vout) can be found from LM317/337 and many other regulators.
Thank you guys for your help. So it will work fine with an lm2941/2991 combo.
And sorry for still asking after all your recommendations, but i am really passionate about this.
But is there any ldo preregulator with fixed noise independant of vout (and is the lt3080 one) and better psrr as an upgrade ?
With properly implemented LT3045/LT3094 there is no need or benefit to have anything special as preregulator. LM317/337, 78xx/79xx or the likes are more than sufficient.
- Power Supplies
- Yet another ultra low noise high PSRR LDO - LT3042
