What type of solid state relays are these ?
There are SMD parts, electronic relays, for audio signal. What kind of relays are these ?
Considering the millions of different smd components on the market it would help a bit more information like:
Make and model of the device that board came from or belongs to.
Schematic for that board.
Just a picture of the component doesn't help much.
I suspect those are short-form manufacturer codes on the packages, there's not enough room on small SMT devices for a real part number - you need to know the manufacturer first and try to find their device marking codes...
It appears to be handling a differential analog signal, so may be a fully differential attenuator/digipot or similar.
Topping E50, is a DAC. That components are after the output stage. They just close and open like a relay but is an electronic one.
No service manual available but there is a software upgrade have you tried that ?
Output relays or muting relays very rarely go bad the last device (different brand) I fixed it was the driver(s) for the relay that was at fault
Fairchild/ onsemi has some output switches of various kinds, maybe you could start looking there? That would be my first go-to place.
I have found nothing in the smd code search.
3710... is the switch USB compatible? What else does the output multiplex with, or why is the switch even there?
year of manufacture? it's possible it's no longer made...
Good luck trying to find anything
https://www.onsemi.com/products/interfaces/analog-switches
You couldn't solder that device like that if it was an XQFN-16 or HXQFN-16 package even if you tried.
Good luck to greierasul in his repair but I'm out.
soldering is the easy part, as is the desoldering, no one is really bonding components with glue like in the 1206 era...
and the component will be NXP/Nexperia as suggested, XQFN16 is almost only made by them.
The component could be something like NX3DV2007GU but I see no such thing, so maybe another name? It's not my job to go over all the datasheets...
