Four 6CK4 Triodes in Uk.
88 Pounds (no pound symbol on my keyboard). Parallel Single Ended in Stereo.
6.3V @ 5 Amps total, AC on filaments works great!
Four 2A3 Triodes in UK.
How many Pounds ($) ?
And, then you have to supply 2.5V DC, 10 Amps total.
If you want to use individual fixed adjustable bias, OK.
Or, If you want to use Individual self bias, you need Four each 2.5V DC @ 2.5A.
Complicated.
Or see if you can get two 6BX7 dual triodes or two 6BL7 dual triodes in UK for Parallel Single Ended in Stereo (6.3V @ 6 Amps total).
Complicated.
You can use "GBP" instead of "£" 🙂Four 6CK4 Triodes in Uk.
Complicated.
£88 is almost decent-output-transformer territory. No way Jose.
2A3->DHT, IMHO definitely not worth the complications, as you rightly pointed out.
Very interesting the 6BX7 and especially 6BL7, thank you for the advice. The 6BL7 is sensibly priced, but a bit annoying that most sellers just have 1 item available. I may buy a couple from ebay.
The reason I'm reluctant to spend too much money is that:
1) I already have 4 6N6Ps. The simulation shows decent results.
2) I'm cheap, living in Scotland for 20+ years, picked some of the good Scottish customs 🙂
But seriously, I will probably give the 6BL7 a try. It's like a souped-up 6SN7, should be easy to use.
Little SEUL amp. I used all Soviet tubes. 6J32P(EF86) triode strapped, 6P14P-EV (EL84) SEUL, 5C4S (5Z4) rectifier, SG1P-EV (0A2) VR tubes.
9" X 7" X 2" Hammond aluminum chassis.
Naughty bits, overall:
Left Channel:
Right channel:
Voltage regulation for the driver tubes:
Power supply:
Volume pot wiring:
That is all.
Left Channel:
Right channel:
Power supply:
Volume pot wiring:
That is all.
Hee, hee. A little silicon poisoning won't hurt anybody. It's a source follower using the VR tubes as a reference voltage to the gate.Is that a mosfet hiding between the VR tubes? looks great!
The software used is solidworks..Very nice presentation. What software are you using?
The 845 electronic pipe power amplifier production process,(1).
The 845 electronic pipe power amplifier production process,(2).
The 845 electronic pipe power amplifier production process,(3).
The 845 electronic pipe power amplifier production process,(4).
The 845 electronic pipe power amplifier production process,(5).
drteming,
That is a very nice amplifier. Cute. Nicely executed.
What UL output transformers did you use?
Manufacturer; Primary impedance, Percent of the UL tap?
Happy Listening!
Happy Listening!
The OTs are from Musical Power Supplies with custom 24% UL tap. 5k primary impedance.drteming,
Happy Listening!
Very good looking and tidy amp, well done!Little SEUL amp. I used all Soviet tubes. 6J32P(EF86) triode strapped, 6P14P-EV (EL84) SEUL, 5C4S (5Z4) rectifier, SG1P-EV (0A2) VR tubes.
Left Channel:
Right channel:
Power supply:
Volume pot wiring:
That is all.
The output transformer I use is 7K.It is my own design.drteming,
Happy Listening!
Variation on a theme, the second of my holiday projects. Not as compact and cute as the first one, but it allowed me to use a larger choke and capacitors (bigger=better?). This amp came about from tinkering with the 6JC5 tube in my 6AV5 amp, and the 6J7 driver for my 6BG6 amp. I don't see the 5879 tube used much around these parts, probably because of the low Gm, but I played with it a while back when I built a Gibson GA-40 clone and liked it a lot. People like to call it the American version of the EF86, but it looks like a miniaturized 6J7, but slightly wimpier. It's driving a beefed up 6V6 which one can do with a slightly undercooked potato. Onward to the pictures.
Overall:
I apologize for the blue LEDs under the driver tubes, but there was no good place for a power indicator light that would preserve the symmetry. Stuffing the LEDs up the tail of the 5879s was the easiest way. There was no blue glow in the 6JC5 tubes. I checked before I stuck in the LEDs.
Guts:
Left channel:
Right channel:
Volume pot and voltage regulator:
Power supply:
This temporarily concludes my vacuum tube endeavors.
Overall:
Guts:
Left channel:
Right channel:
Power supply:
- Tubes / Valves
- Photo Gallery
