I have to say that I use a balanced transimpedace phonostage with 4 low noise Opamps in parallel as the frontend. Because of strong feedback the input impedance is very low.
Well, a virt gnd input is exactly what a transimpedance amp is supposed to present.
Hans
Your Linear Audio article (Vol 0) - Down the rabbit hole?
Jan
The problem with the testers is, that they have precious little time for a review.
In the old days Audio had at least 30 employees to produce the magazine.
Now there are maybe only 5 people and freelancers.
The Art of good testing is mostly lost and forgotten nowerdays.
Jan, I have to read my own article again but the idea for such a stage is not new.
In the old times we called it Dolphin.
Hesener made a Layout years ago.
Attached ;-)
Jan
Here is the Dolphin.
Dolphin was placed under NDA and not yet lifted.
Jan, in the Rabbit Hole article i paralled the opamps out of another reason.
4 times the current drive compared to a single opamp to drive the low impedance feedback network without overload.
Later it showed that i build a much too heavy german tank.
One opamp per side works as well because of the miniscule signal at that point.
Here is a Dolphin for sale from € 1613,77 for € 68,00
Ruffel Price Hike Dolphin Mm Mc Phono Amplifier Movement Ruffel Price Hike Dolphin Mm Mc Phono Amplifier Movement [224554934607] - €68.00 -
Hans
Hans
Please explain why you consider this a "balanced transimpedace phonostage"... Diagram 11683 ...
(11677, 11678).
Waning, Hans are you joking ? This is a fraudulent website.
The "offer" is created by your search using old Ebay etc ads.
Is the world already that bad ?
Hans
About the time I bought the SME 3009 SIII* that I ended up never using to try on high compliance cartridges I had an audio technica AT-34 bayonet mount. Given it's compliance and the weight of AT arms fo the time that was about 6.7Hz. Clearly AT were not worried about low resonant freqency. I kinda wish I hadn't sold that cartridge as it really did perform well.
*5.5g with the standard wand.
With a resonance of 6.7Hz, I'd employ a Sallen-Key filter (thanks to Rod Elliot) to the RIAA preamp outputs to eliminate anything below 18-20Hz.
I've installed them on my various TT setups with excellent results.
No more airborne feedback issues at high volume, no rumble worries, and you don't even miss the woofer-pumping of a warped record, it's gone.
With those issues solved, the amp's power can concentrate on the music.
Project 99 - Infrasonic Filter
