Yep.
Hope it goes well. Keep you posted.
This is showing the Japanese admiration for old Threshold stuff:
https://www.diyaudio.com/forums/attachment.php?attachmentid=989140&stc=1&d=1633805919
https://www.diyaudio.com/forums/attachment.php?attachmentid=989141&stc=1&d=1633805919
Mark Levinson, Nelson Pass were a kind of heroes for the audio community.
Their Shinto believe (I Believe ;-)) says that every object has a soul. So they really like the souls of American made audio gear. They cherish it.
https://www.diyaudio.com/forums/attachment.php?attachmentid=989142&stc=1&d=1633806226
https://www.diyaudio.com/forums/attachment.php?attachmentid=989143&stc=1&d=1633806226
https://www.diyaudio.com/forums/attachment.php?attachmentid=989144&stc=1&d=1633806226
Tantalum to be replaced?
As said I have two S/500 optical bias versions.
Which part of the frontendboard should I replace. A tantalum I believe with what replacing part?
https://www.diyaudio.com/forums/attachment.php?attachmentid=989183&stc=1&d=1633810738
value of Tantalum?
(we are calling them Popcorns, nowadays)
I have no idea.
Will look further.
But is that the offender? That yellow popcorn cap?
yeah
if value permits (size) replace it with solid cap
in size is problematic, put decent electrolytic - these days they're better than Tantals of Yore ....... if nothing else, no Popcorning 🙂
see, He's making me green even with his oldest pcbs .......... two resistors in red
what is exactly written on?
I'm sorry, these where boards from my Threshold SA/1 amps optical bias. So I've now idea what is written on them.
But is it the yellow droplike cap in the vicinity of the green ERO filmcap?
i will look tomorrow for the values. I have a couple of Copper Teflon filmcaps lying around V-Cap CuTF but they are probably too big.
This is showing the Japanese admiration for old Threshold stuff:........
He got them Softies eons ago, and it didn't change in all these years
in recent time ....... Story** goes that our friends from East shores are solely responsible that I was blessed to recognize Best Ever Papamp ......... M2
**Pa didn't had firm intention to make it in volume, but someone willing got prototype....
eons ago - see pic, click
Brilliant stuff.
Very nice pictures indeed.
The guy won't bother to send I have to make all the arrangements.
Thanks to the EU I would wind up paying twice his asking price...
Buy a SL-10 in Europe...
https://www.diyaudio.com/forums/attachment.php?attachmentid=989207&stc=1&d=1633820505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989208&stc=1&d=1633820505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989209&stc=1&d=1633820505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989210&stc=1&d=1633820505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989211&stc=1&d=1633820505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989213&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989214&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989215&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989216&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989217&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989219&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989220&stc=1&d=1633820794
https://www.diyaudio.com/forums/attachment.php?attachmentid=989221&stc=1&d=1633821070
https://www.diyaudio.com/forums/attachment.php?attachmentid=989222&stc=1&d=1633821070
https://www.diyaudio.com/forums/attachment.php?attachmentid=989223&stc=1&d=1633821070
https://www.diyaudio.com/forums/attachment.php?attachmentid=989224&stc=1&d=1633821070
https://www.diyaudio.com/forums/attachment.php?attachmentid=989225&stc=1&d=1633821070
https://www.diyaudio.com/forums/attachment.php?attachmentid=989226&stc=1&d=1633821505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989227&stc=1&d=1633821505
https://www.diyaudio.com/forums/attachment.php?attachmentid=989228&stc=1&d=1633821505
Probably at home at Rene Besne, Pass loved the small Thresholds with Horn loudspeakers I believe always a modest man.
https://www.diyaudio.com/forums/attachment.php?attachmentid=989229&stc=1&d=1633821505
In the 70's, they (Signal Transformer) were at 1 Junius Street in NYC - Brooklyn, maybe? They were the go-to XFMR supplier for budding amp builders in my dorm at MIT. The transformers were immediately recognizable due to the black impregnating varnish used.....
I can spot one across the room. Not only excellent and low-price power transformers. A forum transformer wizard presented a set of audio frequency response curves for public guessing. I held-back because I knew from the bobbin, and my own testing, what it was. The small Signal "2-4-1" power transformers had quite wide frequency response at medium audio impedances. Well past 50-15k.
Anyway: I can't see the line terminals on that PCB. But the transformer fully supports dual-primary 120/240 operation, you just have to find and sort out four connections.
- AC Converting a Threshold NS-10
