Help me decide on room treaments.
Hey guys!
So i finished making my K-402 MEH in wood and brought them in a large room.
There is only A TV desk, speakers, a sofa and that's it.
This is how the room currently look like:
attachment.php
The RT60 times a very huge:
attachment.php
Since this a huge horn with directivity control down to 100Hz, i figured i don't really need much of 'first reflection' treatments. What i need is to treat walls near the edges of the horn and somehow reduce the reverberation time of the room.
I will be placing QRD diffusers on the ceiling covering 3 meters between listening position. To cover half of the space i will need about 13 of them.
This will be made out of high density XPS, painted and look like this:
attachment.php
Will place a rug on the floor between the sofa and listening position.
And on the side walls near the sofa i am thinking of placing Leanfractal diffusers. 3 pieces on each side wall.
Leanfractals on the front and side walls will look like this:
attachment.php
Oh, and 5 diffusers on the back wall with some furniture:
attachment.php
Will it be enough to deal with excessive reverberation? Or do i need more absorption rather then diffusion?
Joined 2009
To lower RT you'll need absorption. Diffusion won't hurt ( quite the opposite) and maybe it'll be enough to make the room sound good to you despite an high RT.
But if you need to lower RT i see only two way: either absorbption either some 'hangers' ( but you usually need high ceiling for them).
Joined 2009
Hi Kipman725,
Ime superchunk is ok on low ( around 100hz and a bit less) but they do almost nothing lower in freq ( at least for the one in the room i've implemented them).
I agree these is a very nice room.
Stabme what is ceiling height?
If i was in need to lower reverberation time i would implement an absorbent ceiling: something like rockwool tiles ( rockfon) with 100mm rockwool right over them and a plenum ( free space) of 100mm too with a bit of space ( something like 10mm all around the walls).
It should be effective as a wideband absorber ( when i built control rooms it was the standard practice for ceiling for the acoustician i worked with). You could implement diffuser of same dimension that the tiles too a little in front and above ( if you need them) like this one ( other finition exist) : RT60 - Diffuseur acoustique transparent
Following this thread, what would you do to get max absorbtion between 50-100hz?
Manu
Hi Kipman725,
Hi Kipman725,
I have 4 of them in our house, but they are super ugly. The rear corners are occupied by the furniture and front corners are not an option because i am using large MEH horns and i like to corner load them.
A nice one, indeed - thank you! Only very boomy at this time. BTW, i feel that I have become very adapted to the RT in this room. Ceiling height is 3 meters (9.84ft).
Sounds like an option, yes. I will try the XPS diffusers first - they will be ready in about a week or so.
Yes, read about it and thought about it. There is a good study by Fazenda who compared sifferent sub setups and found that source-sink setup (DBA, basically) was most preferred by listeners.
I have full range 2-way speakers located in corners. These are K-402 horn based multiple entry horns. They can be seen on the original post in this thread. They go down to about 25-30Hz. So sub-band is kinda covered in the front of the room. So i could start by adding two inverted and time aligned subwoofers on the rear of the room and see if that makes a good difference.
Installed diffusers on the ceiling:
attachment.php
The area is 3 by 3 meters, 9sq/m total. 13 pieces are 2D, which, according to QRDude, will diffuse between 600-2100Hz. Other 12 pieces are 1D diffusers which work at around 2200- 6800Hz.
Hope that mixing 1D and 2D diffusers is not a big problem.
