Some speaker driver measurements...
Thanks everyone for the kind comments, this speaker was a very ambitious project for me, my best work to date. If it isn't obvious, the baffle is solid African mahogany, with maple inlay, and the sides are maple veneer. Not photographed is a CSS APR12 passive radiator on the back.
Are you crossing those amts passively, and if so, how do you deal with the early HF rolloff?
The key is to not focus too much on single axis response. I tried a few different things, but found what sounds best is to follow VituixCAD CTA-2034-A method and tune for constant slope of in-room and power response. Screenshot attached. You will see, that most of the natual rising response of the AMT is left in place here, but in-room and power response are flat to 10kHz as a result of the tweeter directivity profile and crossover involved. It is not perfection, unfortunately the very top end performance of the AMT is the weak link in this speaker, but it is still incredibly enjoyable to listen to, the tonality through the midrange and bass is perfect.
In the screenshot, don't read too much into the midbass response, it is real hard to get accurate measured data with woofer at floor level, as well the PR output is not included here for the bass performance <100Hz. On the other end of the spectrum, the wiggle at 7kHz was only present in one of my AMTs, the other measures perfectly without the wiggle. I even went as far as to disassemble and inspect them, but I couldn't see any problem, reassembled and nothing changed. My ears cant tell the difference between the two tweeters when listening so I am not very concerned.
Ok..back to the thread, sorry to derail a bit.
I'm glad you chose mahogany for the baffle.
It has been used for large cameras and other optical devices for several score of years, for its dimensional stability and relatively low transmission of vibration.(it is considered a 'tone wood', but a soft mellow one)
Stain-friendliness doesn't hurt, either.
lovely work, in any case.
Thank you. No stain here, it is tung oil with a gel poly coat on top for added durability.
I put a couple battens on the inside of the baffle to help prevent any warping, and it is attached with gasket and screws from behind, no glue on the baffle. It's been over a year now with no visible changes whatsoever so I think my assembly process was good for the solid baffle.
I don't think too many would mind -bloody amazing job and I am sure you are not missing too much with that AMT top end -Dayton worked with PBS loudspeakers to create a reference design with this driver a few years back and it was supposed to sound terrific -bright red. Thanks for showing part of the design phase
The measurements of the Seas T29CF002 (E0040-06) "Crecsendo" tweeter:
Seas T29CF002 (E0040-06) "Crecsendo" | HiFiCompass
Thanks this driver I really was looking forward to the test - it was popular in Australia years ago in your opinion does it still stand up today with the best tweeter's ? And what stopped a 5 star rating was it the cost or linearity appreciate your response. It is listed at $640 each in Peso dollar Australia now -ooch ! I am not seeing that kind of performance. Did you listen to it ? And could you see you ever using it in a design?
cheers
