Acoustic Horn Design – The Easy Way (Ath4)
looks close to perfect
it's hard to imagine there will be many more appropriate phase plugs to give this idea the best chance of success. The ND4015 series suggests at least some of the design choices decisions concerning the throat. The vanes can come close to the ends of some or all of the phase plug terminations.
There are several other decisions that come to mind, some of which have been mentioned. These all look hard to me.
Above 10kHz, the radially-symmetric diaphragm modes are going to come through. I wouldn't know whether it's better to blend some of the rings at the throat (one or two vanes) or keep them all separate.
It will take judgement to decide how much to thicken the vanes as they extend outward, and at what rate.
I can't see how to decide the length of the vanes. For a pure OS, I wonder about ending the vanes on a sphere (or oblate sphere) at the mouth, i.e., the middle vane should be longest. I've no intuition what will happen or what to do with an OSSE type guide - I'm thinking of all your roll-back trials, and can't start to imagine how to fit all that together.
Ken
For those of you who want to try simulating, here is a way to generate the contours in Fusion360
There is a addon called Equation Driven Curve. It can be used to draw the OS contours with the help of a few predefined user parameters.
The equation in Fusion style: sqrt(( sin(a) ^ 2 / sin(a0) ^ 2 ) * k ^ 2 * r0 ^ 2 + t ^ 2 * tan(a) ^ 2) - ( sin(a) / sin(a0) ) * r0 * ( k - 1 )
attachment.php
attachment.php
I multiply the S parameter to get the offset curves (in my case by 0.2, 0.4, 0.6 and 0.8)
Why do you think the vanes will need thickening at all? My understanding is that the thinner the better and that there's nothing better that one could do about it (?).
Regarding the extension towards the mouth, I think it will only work as long as the wall contour really follows the OS profile, which is also why I wouldn't extend the vanes more than about 1/4 - 1/3 of the profile. Then it's not an OS anymore.
Anyway, BEM simulations should answer us all these question soon.
ends
By thickening, I meant a little, for stability. The vanes should be thin at the throat, I wonder if the optimum is to have them thin there and thicken - only enough for stability, if at all - farther down the waveguide where small deviations from the "ideal" are less problematic.
I look forward to seeing some BEM results - if the vanes can be that short it would be convenient and allow them to be kept thin.
Ken
Being conical-like, the vanes should be very stable and not need thickness for support.
The issue not being addressed is termination. As usual, the waveguide and vanes must be terminated. If this is not done properly then diffract6ion will occur. I think that the vanes should go out to the point where the OS contour is deviated to supply the flare. If they go any further then the vanes won't be normal to the wavefront and there will be diffraction at the termination.
I would use a single vane to start as multiple vanes only make the situation more complex with no apparent advantage.
I already printed some on a FDM 3D printer just for a test and don't worry much about stability (this was PLA, 0.4 mm thickness, it's actually printed just as one spiral). But it needs an additional coating as it's not 100% airtight (I suppose it should be).
If epoxy coated I think it will be quite stable.
- But perhaps it shouldn't be airtight, I don't know. What if it was perforated?
I suspect that it would would as well or better. 0th mode waves won't see a pressure differential. HOMs will. They could get damped instead of just reflecting.
So everything went quite esoteric lately, wow! I don't have anything to contribute to the multi cell coaxial story. Patrick: Though it is neat to print the foam permanently into the waveguide, it does not sound wise. It will be impossible to replace it and cleaning it from dust could only be done in a big ultra sonic cleaner. In any case: if the foam could be printed, it should be a seperate piece.
Now, I want to share my impressions with the idea to add a slotted throat. In the end, I could not really break through the brick wall that is at 15k. When Source.Shape = 2 is set, it does look very much better, but as noone knows whether this mode or Source.Shape = 1 represents actual HF behaviour, it does not seem to give a lot. Attached 4 graphs, first two in mode 2, HF peak with the unslotted, slotted shines, second two in mode 1, HF with unslotted look better than slotted in mode 2. I went to the extremes of Slot.Length = n*cos(2*p)^n, tried more than four slots (times*p) and made them wider, still a 15k brickwall, more or less. I could not figure how to make them very long but not widen, so that they would reach deep into the termination, but that is all I have missed. Until there is some other idea, I think I will go for an axisymmetric device.
The only thing that I could see is that the -1 and -6 dB lines seem to behave differently if you compare the first and last (best looking) graphs.
So 🙂
I have implemented all the above discussed functionality into Ath, including export of the contours into ripple tank. After the very first attempts, this is what I was initially worried about - dividing the waveguide into several "discrete" channels simply won't sum smoothly at the exit of the vanes. So far I was not able to obtain a significantly better result than without the vanes.
Anyway, it's fascinating to watch - here's a sample Ripple Tank code (Ripple Tank Simulation)
Code:
$ 3 2000 125 0 0 728 0.00037463
S 2 251 837 251 1163 0 0.01637368881118881 0 10.000178395549446 99.9998652719957 1 0
w 0 250 836 250 1164
w 0 250 1164 252 1164
w 0 250 836 252 836
w 0 252 1164 255 1164
w 0 252 836 255 836
w 0 255 1164 257 1164
w 0 255 836 257 836
w 0 257 1164 260 1164
w 0 257 836 260 836
w 0 260 1164 263 1164
w 0 260 836 263 836
w 0 263 1164 267 1164
w 0 263 836 267 836
w 0 267 1164 270 1165
w 0 267 836 270 835
w 0 270 1165 274 1165
w 0 270 835 274 835
w 0 274 1165 278 1166
w 0 274 835 278 834
w 0 278 1166 283 1167
w 0 278 834 283 833
w 0 283 1167 288 1168
w 0 283 833 288 832
w 0 288 1168 293 1169
w 0 288 832 293 831
w 0 293 1169 299 1171
w 0 293 831 299 829
w 0 299 1171 304 1172
w 0 299 829 304 828
w 0 304 1172 310 1174
w 0 304 828 310 826
w 0 310 1174 317 1177
w 0 310 826 317 823
w 0 317 1177 323 1179
w 0 317 823 323 821
w 0 323 1179 331 1182
w 0 323 821 331 818
w 0 331 1182 338 1186
w 0 331 818 338 814
w 0 338 1186 346 1190
w 0 338 814 346 810
w 0 346 1190 355 1194
w 0 346 810 355 806
w 0 355 1194 364 1199
w 0 355 806 364 801
w 0 364 1199 373 1204
w 0 364 801 373 796
w 0 373 1204 382 1211
w 0 373 796 382 789
w 0 382 1211 393 1217
w 0 382 789 393 783
w 0 393 1217 403 1224
w 0 393 783 403 776
w 0 403 1224 414 1232
w 0 403 776 414 768
w 0 414 1232 426 1240
w 0 414 768 426 760
w 0 426 1240 437 1248
w 0 426 760 437 752
w 0 437 1248 450 1258
w 0 437 752 450 742
w 0 450 1258 462 1268
w 0 450 742 462 732
w 0 462 1268 475 1279
w 0 462 732 475 721
w 0 475 1279 490 1290
w 0 475 721 490 710
w 0 490 1290 503 1302
w 0 490 710 503 698
w 0 503 1302 518 1314
w 0 503 698 518 686
w 0 518 1314 534 1327
w 0 518 686 534 673
w 0 534 1327 549 1341
w 0 534 673 549 659
w 0 549 1341 565 1355
w 0 549 659 565 645
w 0 565 1355 582 1370
w 0 565 645 582 630
w 0 582 1370 598 1384
w 0 582 630 598 616
w 0 598 1384 615 1400
w 0 598 616 615 600
w 0 615 1400 633 1416
w 0 615 600 633 584
w 0 633 1416 650 1432
w 0 633 584 650 568
w 0 650 1432 668 1449
w 0 650 568 668 551
w 0 668 1449 686 1466
w 0 668 551 686 534
w 0 686 1466 705 1484
w 0 686 534 705 516
w 0 705 1484 723 1501
w 0 705 516 723 499
w 0 723 1501 741 1518
w 0 723 499 741 482
w 0 741 1518 761 1536
w 0 741 482 761 464
w 0 761 1536 779 1553
w 0 761 464 779 447
w 0 779 1553 798 1572
w 0 779 447 798 428
w 0 798 1572 816 1589
w 0 798 428 816 411
w 0 816 1589 833 1606
w 0 816 411 833 394
w 0 833 1606 852 1624
w 0 833 394 852 376
w 0 852 1624 870 1641
w 0 852 376 870 359
w 0 870 1641 887 1658
w 0 870 359 887 342
w 0 887 1658 904 1674
w 0 887 342 904 326
w 0 904 1674 921 1691
w 0 904 326 921 309
w 0 921 1691 938 1707
w 0 921 309 938 293
w 0 938 1707 953 1722
w 0 938 293 953 278
w 0 953 1722 969 1738
w 0 953 278 969 262
w 0 969 1738 984 1752
w 0 969 262 984 248
w 0 984 1752 998 1766
w 0 984 248 998 234
w 0 998 1766 1012 1780
w 0 998 234 1012 220
w 0 1012 1780 1026 1793
w 0 1012 220 1026 207
w 0 1026 1793 1039 1806
w 0 1026 207 1039 194
w 0 1039 1806 1052 1819
w 0 1039 194 1052 181
w 0 1052 1819 1064 1830
w 0 1052 181 1064 170
w 0 1064 1830 1075 1842
w 0 1064 170 1075 158
w 0 1075 1842 1087 1853
w 0 1075 158 1087 147
w 0 1087 1853 1097 1862
w 0 1087 147 1097 138
w 0 1097 1862 1107 1873
w 0 1097 138 1107 127
w 0 1107 1873 1117 1882
w 0 1107 127 1117 118
w 0 1117 1882 1126 1891
w 0 1117 118 1126 109
w 0 1126 1891 1134 1899
w 0 1126 109 1134 101
w 0 1134 1899 1143 1908
w 0 1134 101 1143 92
w 0 1143 1908 1150 1915
w 0 1143 92 1150 85
w 0 1150 1915 1158 1922
w 0 1150 85 1158 78
w 0 1158 1922 1165 1929
w 0 1158 78 1165 71
w 0 1165 1929 1171 1935
w 0 1165 71 1171 65
w 0 1171 1935 1177 1941
w 0 1171 65 1177 59
w 0 1177 1941 1183 1947
w 0 1177 59 1183 53
w 0 1183 1947 1188 1952
w 0 1183 53 1188 48
w 0 1188 1952 1193 1957
w 0 1188 48 1193 43
w 0 1193 1957 1197 1961
w 0 1193 43 1197 39
w 0 1197 1961 1202 1966
w 0 1197 39 1202 34
w 0 1202 1966 1205 1969
w 0 1202 34 1205 31
w 0 1205 1969 1209 1973
w 0 1205 31 1209 27
w 0 1209 1973 1212 1976
w 0 1209 27 1212 24
w 0 1212 1976 1215 1979
w 0 1212 24 1215 21
w 0 1215 1979 1218 1982
w 0 1215 21 1218 18
w 0 1218 1982 1220 1984
w 0 1218 18 1220 16
w 0 1220 1984 1222 1986
w 0 1220 16 1222 14
w 0 1222 1986 1224 1988
w 0 1222 14 1224 12
w 0 1224 1988 1226 1989
w 0 1224 12 1226 11
w 0 1226 1989 1227 1991
w 0 1226 11 1227 9
w 0 1227 1991 1228 1992
w 0 1227 9 1228 8
w 0 1228 1992 1229 1992
w 0 1228 8 1229 8
w 0 1229 1992 1229 1993
w 0 1229 8 1229 7
w 0 261 1082 282 1083
w 0 261 918 282 917
w 0 282 1083 303 1084
w 0 282 917 303 916
w 0 303 1084 325 1087
w 0 303 916 325 913
w 0 325 1087 348 1090
w 0 325 913 348 910
w 0 348 1090 371 1094
w 0 348 910 371 906
w 0 371 1094 396 1099
w 0 371 906 396 901
w 0 396 1099 422 1104
w 0 396 901 422 896
w 0 422 1104 449 1111
w 0 422 896 449 889
w 0 449 1111 478 1119
w 0 449 889 478 881
w 0 478 1119 510 1128
w 0 478 881 510 872
w 0 510 1128 544 1138
w 0 510 872 544 862
w 0 544 1138 581 1149
w 0 544 862 581 851
w 0 581 1149 621 1162
w 0 581 851 621 838
w 0 621 1162 664 1177
w 0 621 838 664 823
w 0 664 1177 711 1192
w 0 664 823 711 808
