LM3886T - Original or Bootleg?
1) when quoting please edit message as I am doing now, no need to repeat it IN FULL when it´s just above, only leave *one* text line to identify it.
I texted the seller and they sent me these pictures, the IC looks better than the ones they have on their shop and I think they look identical to the original... what do you guys think?
I built up my first LM3886 amp a good few years ago.
The thing wouldn't work.
It was a reputable source so should have been good.
I had volts on output when it should be zero volts.
I then spotted the mistake.
The long pins were shorting on the pcb pads of the back pins.
So the next one I soldered in I left it a little proud of the pcb and it worked fine.
THREE? Gee, why don't you put a capacitor in series? Or look at the output with a 20 Ohm resistor? Or put an expendable speaker from an old TV etc in series to it.
Especially if it’s a tweeter - should be using a cap anyway. If it’s the woofer it would have to be pretty small for 20 volts to kill it before you can get to the power switch.
I think they are not lm3886, the writing looks funny , it might be National/TI part, but not lm3886.
The one on the left at least is Laser engraved and *looks* professionally made, the one at right has TERRIBLE silkscreening, I can print much better on my kitchen table with one hand tied to my back.
Even worse: fully enlarging the image I can see the *thin* sharp outline of each letter, surrounded by a flood of white ink.
As a silkscreener: they had a well made original artwork, proper line thickness, etc, then inexperienced/cheap/in a hurry operator had a problem with ink drying up and clogging screen pores (a very common problem) so he added ink solvent ... way too much of it, so too liquid ink spreads too much around.
If silkscreening is that sloppy, imagine what they fit inside 😎
Most probably you can wipe that white ink out with a ball of cotton wetted in acetone.
We can´t add anything new to what is already written, just take the plunge and buy the U$13 one, I suggested a somewhat safe way to test it.
OR:
Pllan B: ditch the LM3886 idea and build a conventional discrete 50/60W amp.
It´s easier to find real discrete parts and if they fail they can be repaired.
I use TIP142/147 since about 2006 because of that, not expensive or unavailable enough to attract fakers.
Unless you buy 10 for 1.25 US$ from some ignote seller in China, but then you love playing Russian Roulette 😛
Thanks.
May be authentic, still stand by my very poor silkscreening comments 🙂
Since everybody and his brother went to laser engraving years ago, only way I would expect a silkscreened part from a major manufacturer is from very very old NOS.
Out of curiosity just checked a few old parts drawers: silkscreened ones showed dates from ´74 to ´97, one had a single digit code starting with 7 , might be ´97 or even 2007, all others were laser burnt.
I would be very skeptical that there IS any NOS 3886 or TDA2050 left on the planet. The last of the original runs would be long gone and only recent manufacture 3886 would be available at all. If you’re looking for TDA2003 (and sometimes even 2030) you can still find them because nobody uses them anymore, and predecessors of the 3886 seem to be more available. NOS on all the predecessor types may still be around after the 3886 evaporates entirely.
If they do decide to EOL them it will be a mess - like the mad scramble to get the last 2N6609’s and Sanken MT200’s were. Maybe not enough industry demand anymore, but a lot of angry users left holding the bag.
Thanks everyone for your help, Ive decided to buy the LM3886 from this seller and just hope for the best. I initially asked because the IC in their pictures looked suspicious but now I know that the pictures are taken online and their actual units look more decent i'll take the risk.
I can try to arrange some NOS LM3886T if you want to.
YES, still available here but not sure about quantity. Insulated package is more popular here than non-insulated 'T' version for ease of use & maybe that's the reason no one wants to buy those 3886T despite technical superiority.
