BTSB Buffer - SE/Bal to SE/Bal Buffer GB
In case anyone who is wondering if the BTSB works well with the Pass DIYA VFET lottery amp... yes, it works superbly. The VFET amp sounds really special, but only has 10dB of gain so it’s going to need some preamp help. I used mine at 14dB for 24dB gain overall and it’s sublime. If you want to drive it with your phone, you could select the 20dB gain setting even.
949832d1620456692-diy-sony-vfet-builders-thread-vfet-amp-build-rear-panel-07-jpg
Agreed! 😀
My freshly wired up BTSB is playing well between my preamp and my VFET SE!
Started with +6db to test. May go up to 10 and see if that also works.
My main reason to add gain was to boost my vinyl playback. But everything could use a little more, so trying this route first. First record going on shortly...
Ha! Thanks. So, just to confirm, which direction of the dip switches ‘actuates’ that selection? Toward the output?
Would this not be 6db?
Edit: I understand now that I typed 10db when I should have typed 14.
I made a 3d printed case for the TH BTSB. As XRK mentioned a very handy accessory to have on hand for connecting almost any source to any amplifier.
  • 3D_printable_BTSB_case.zip
