I've read the majority of the thread so apologies if I missed it. I have taken delivery of Prasis AB100 layout.
If I am reading the schematic and board right then R16 10.1 is linked to F1 via jumper wire J3. Thick white line along the top edge.
Looking at my board J3 doesn't go to F1 but to GND.
Do I need to do a little modification?
The stuffing guide image i have been referring to is the same as my PCB.
I'm sure this is my inexperience and not an error!
That is a ground trace coming from the input side, since your pcb are already manufactured double sided, there is no need for any jumpers or modification, there is already a trace on top copper. Board is fine as is.
For singled sided diy etching of pcb, jumpers are required.
refer this post regarding value of R3.
AB100 Class AB Power Amplifier
I chose AB100 and also FH9 as the rail voltage matches my current 3255 class d @50vdc. So I can swap my power amps with the same trafo. Admittedly different psu for dual rail on the AB amps..
Thanks for all the help so far. Big mouser order placed.
Would you care to share your Mouser cart?
I am curious to see what components you chose.
Thank you Mr. Pass , Prasi , Oscar and everybody else who has contributed to this thread .
I have a couple of questions regarding part choices :
1. Is it OK to substitute KSA1381/KSC3503 for 2SA1380/2SC3502 which are available in South Africa ? Dissipation 7W vs 5W ; Max VCBO ±200V vs ±300V
I see the devices Mr Pass initially specify - 2SA1110/2SC2590 have even lower Max VCBO ±120V .
2. I have 2 types of BD139 , BD139_10 (Hfe 60-160) and BD139_16 (Hfe 100-250) . Would BD139_16 be the better choice ? That seems to be in the ballpark of the original ZTX450 .
3. I got ON TIP142G & TIP147G (TO-247) , I see Jan got MJ's , I'm wondering if I should sell the TIP's ? Edit : Oops ! I see Jan replaced the MJ's with 2SA/2SC
4. I got the recommended BC547/557 B-rated , any better recommendations ?
Thanks guys !
Thanks guys !
Hallo Ari, NO do not sell the TIPs, I have used them , maybe a mis understanding or mis wrote.
RS Components | Electronic and Electrical Components
I have used BD139-16
- AB100 Class AB Power Amplifier
