PeeCeeBee V4H GB
Hello,
I m having problems, the leds on my boards did not lit up.
Before connecting everything i checked every board carefully.
Before connecting the power supply i checked continuity between the legs of the ics and heatsink. No continuity.
After connecting power supply and power up i have some continuity between the drain of the mosfets and ground/heatsink.
....i built a lot of amps and dacs even with smds etc.. never had problems...
Continuity with heatsink is bad, did you use an insulator under each mosfets and transistor attached to the heatsink?
Also make sure the heatsink has a ground for it to the PSU.
Using two is only 4 watts, so make sure you keep it very low only for function testing or any power testing and they will burn very quickly
Yes they all have insulators.
I did not connect the multimeter probes to r25 or 26 but i think it is not needed for the leds to shine or it is needed?
Heatsink is connect to 0v on power supply.
You have something wrong, check to make sure LEDs are correctly oriented first.
Next, with no power , check all pins/legs of the mosfets and transistors on the heatsink... continuity mode, black probe on heatsink - none of the pins/legs for the mosfets or transistors on the heatsink should would continuity.
If you hear a “beep” or see OL on your meter, do not power up, you must figure out which one is the issue and correct this issue before powering up.
Be sure you use the DBT until you are confident everything is working and no issues only then do you power up without the DBT.
I disconnected ps wires and checked all legs one by one to the heatsink i have no continuity, no beeps. Black probe to heatsink.
Checked the leds , i think they are ok.
I would suggest putting together a DBT (Google will help) and get a 100w incandescent bulb.
Then recheck everything when you have it together with you meter for shorts. For this take out the resistors on the power rails, it might confuse the meter.
If any legs of outputs or drivers on heatsink show continuity, you need to figure that out.
You should not try anything until you have no shorts detected.
I m out but i have a dbt at home and i will test it.
Hello, i removed the resistors, connected the DBT with a 60 watt incandescent bulb that was what i had at home.
Before power up i checked every ic leg continuity to ground and no shorts.
Powered up and the bulb got bright than right after turned dim until off. Them i powered off but the leds on the board did not shine...
Go slow, 1 channel at a time and use the DBT until you have consistent results then full power. Then do the same process with the other channel.
Then power it up with both channels straight power and have your hand on the plug in case any thing smokes or gets too hot, monitor for at least 30 mins before you think about leaving it unattended.
[emoji106]vas biasing done in one board and offsett trimming also.
For the mosfets... since i dont have the resistors now connected(2x1.8ohm paralell).. i don t know how to do it.. maybe tomorrow i will buy 1ohm resistors... and continue.
I have 0.9ohm...is the same value for mosfet biasing?
Also need to desolder the leds on the second board also and reverse.....
