LuFo Amp - 39w SE Class A from 28v Rail
LuFo PCBs are in the house! These things are huge! Very nice work by JPS64 - thank you, JP! Hand-placed 21,000 via holes on this board. I think that’s a new record.
attachment.php
Marantz 7 should be able to drive 50Vpp, but it is not the best option IMO and E to drive the gate of a power fet.
12AX7 tubes run on low current, despite the fact that it has a CF output; I saw a schematic with two 12AX7 in series with feedback to get the voltage amplification down to workable values, followed by 12AX7 cathode follower...arghhh...my tube heart hurts...
A much better option will be an Aikido preamp/driver stage.
A 6N1P as input tube and a potent tube as cathode follower (5687; 6H6P; ECC99) would give a stage with a bit over 1 VRMS sensitivity to drive a LuFo.
Broskie has high quality PCB's and multiple options as well for power supply.
A Broskie CCDA might work equally well, however, as LuFo is a quiet amp an Aikido might be a better fit.
Here is a Broskie Aikido Noval:
New topic - LuFo as headphone amp:
I ran some simulations with 24v supply and a 20mH 0.5ohm inductor. The results were very promising as a headphone amp driving a 32ohm load. I might have to give this a try - will need to order these iron core speaker inductors.
ERSE Super Q 20mH 16 AWG 500W Inductor Crossover Coil
I was getting nothing but second harmonic distortion at 500mW into 32ohms (a little under 12vpp) and 0.0007% THD.
With mere simulation don't you take possible core saturation out of the equation?
I'd like to see some real measurements with MOT's running in a 3A DC bias LuFo driving an 8 ohm load at 20 Hz full power.
That would give real info on the requirements for these chokes.
In the meantime I also had a prototype choke wound on a 300 watt c-core.
It has some 0.4 ohm DCR and 50 mH induction; this induction is measured with a (professional) induction meter at 100 Hz and 250 mV sinus.
It has quite an airgap, but behaviour must be checked in a working amp; I would not be surprised if a 600 watt core is required in the end.
That is a nice looking choke.
