LuFo Amp - 39w SE Class A from 28v Rail
Over in ACP+ thread, Mark Johnson said that the Dreadnought FE board can do 53vpp. So there are options out there for preamps to drive the LuFo for sure. Here was the Dreadnought Oscope screen shot at 53.4Vpp:
943943d1618838868-scourge-bulwark-marauder-dreadnought-front-cards-diy-vfet-amp-dread_30khz_sine-png
Dreadnought appears similar to a Blameless architecture?
I have the key components (PCBs, Mosfets, tubes) for a Borbely hybrid line amp:
https://www.pearl-hifi.com/06_Lit_A..._Amps.pdf#[{"num":38,"gen":0},{"name":"Fit"}]
Can be configured for >30dB of gain so looks like a good candidate to drive a LuFo (or similar power buffer). There seems to be an aptness about using a line amp with obsolete Mosfets to drive a power buffer based on obsolete output devices (such as the LU1014D, Tokin SITs, etc).
I would imagine that the harmonic profile of the Dreadnought (being similar to a Blameless topology) might have the 2nd and 3rd order distortions closer together in level, and perhaps more higher orders present. Whereas the Aksa Lender was designed to be second order dominant, with monotonically descending higher orders, and few higher orders presemt. In my HOWTO thread on distortion measurements using REW, I used the Aksa Lender as an example of what an FFT can look like driving 20Vpp into 7kohms:
654180d1514879318-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-20vpp-7kohm-fft-rt-png
Here is the FFT for 51.4Vpp (a little more than what is needed to make 39w into 8ohms in the LuFo) at about 0.013% THD and very little higher harmonics:
654183d1514880354-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-51-4vpp-7kohm-fft-59vcc-png
If anyone has FFT measurements of a Dreadnought to show, that would be great.
Vunce is getting a head start on building the LuFo amp verification build. He has chosen an old Odyssey Stratos amp as the donor chassis. It has the size to handle the LuFo as a dual monoblock in single chassis. It’s going to be a monster with a 500VA trafo and two 8lb MOTs. Also two single rail SLB power supply boards. Probably an SFP will be thrown in for soft start duties as well. I suspect upwards of 70lbs when completed. 😀 Watch your back, Vunce!
attachment.php
attachment.php
attachment.php
Hi WT,
I’ll send you the LuFo PCBs as soon as it gets here. Shouldn’t be more than another day or two. That PSU of yours should be fine - I assume it is a linear supply given the massiveness?
On my end, I will be building mine up as a pair of monoblocks. This is what I have in mind and about to place an order for this chassis: 160 mm W x 192mm H x 348mm D internal dimensions, 10kg (each).
attachment.php
attachment.php
attachment.php
I have a duplicate of this chassis that may be suitable for some pretty decent power. It is about 3.5U tall, 400mm deep and has extra large fins. Internal space is at a premium for the serious iron needed for this project, but I think I can make it fit with a 600VA Antek transformer and a pair of MOT. Probably insufficient room for the Hammond 195T5, though.
Hi TA,
That’s a nice chassis. Fitting a toroidal, two MOTs and a pair of SLBs would indeed be tight. What are the internal dimensions? Maybe have a separate chassis for the trafo and two SLBs like you did on the VFET amp?
Really nice work you did on the standalone dual SLB PSU chassis for the VFET, btw. For the LuFo, you could use a single 500VA 25v toroidal can use each secondary for a separate SLB.
958503d1623249327-diy-sony-vfet-builders-thread-img_1106-jpg
I have been discussing with Zman01 on how to deal with acquiring a suitable microwave oven transformer if you live in a country with 220vac mains. The primary windings on a MOT are generally too high of an impedance (longer thinner wire?) . There are plenty of YouTube videos that show how to remove and rewind your MOTs. If you have no interest in preserving the wire that is already there, diagonal cutters, chisel, hammer, maybe a screwdriver will pretty much make you dangerous enough to strip one clean and bare. The core is left and it is welded shut - but that core is like Gold in audio. One could find 14ga (1.6mm dia) copper magnet wire (insulated with varnish) and rewind yourself. Once the secondary had been removed, there is plenty of room. Winding 1.6mm dia copper wire is not easy, but the cost savings might be worth it. Also, it’s near impossible to find a 68mH 10A 0.5ohm DCR choke at a reasonable price.
I wonder if a lb of 14ga magnet wire (80ft) is enough? I think so because the primary I see on my MOT is a way smaller spool of wire than this.
14 AWG Gauge Enameled Copper Magnet Wire 1.0 lbs 80' Length 0.0655" 155C Red | eBay
BEST Microwave Oven Transformer-MOT Rewinding Tutorial - YouTube
How To: Rewind Microwave Oven Transformer, Trash To Treasure! - YouTube
Cheap 'N Easy ZVS Build 2/5: Rewinding a microwave oven transformer for an induction heater - YouTube
This is DIY audio right? We can’t expect everything to be premade for us. 🙂
MOT cores are not audio grade quality; they are for a totally different application.
Why build a nice class A amp and don't spend enough for one of it's most critical parts??
Aren't you guys aware of the fact that the quality of core material matters a lot??
Check tube amps and what is writen on this forum about the importance of output transformers and how they affect sound quality.
The quality of the choke for a LuFo amp is as important as output transformers are for tube amps.
You want DIY, but done right?
Then buy some good quality c-cores and 1.5 mm² home electrical wire (here in Europe the black insulated stuff) and wind your own quality choke!
This is a good one for US residents:
CD25x50x100 C-core - BRIDGEPORT MAGNETICS GROUP
Tune required DC resistance and inductance with the correct number of turns, applying the right air gap for 3 A DC current without core saturation.
C-cores are ideal for DIY as you don't have to (dis)assemble E's and I's, and tuning the air gap is easy.
Europeans: check SU90b c-cores which are also rated for some 600 watts.
When interested I have a friend willing to do some support.
Thanks for posting. I have no experience of winding transformers and wouldn't know where to start or what to buy but I'm willing to give it a try. Do you have any pointers to good 'tutorials' on how to calculate what's needed and/or the practical aspects of the winding process. I know I could 'google' but would like to improve the signal to noise ratio.
Daanve,
Thanks for sharing this info, sounds interesting.
I would request you to open a separate thread on this, as the topic deserves a thread of its own, as it is likely that there will be a lot of discussion, learning and trying involved.
Having this discussion on the LuFo thread is likely to hamper the continuity here on LuFo developments, and on the other hand LuFo updates will break the continuity of inductor winding related discussions.
That's a nice chassis.
The Hammond 195T5 is a monster... I checked the specs and saw that it weights 14 lbs. Imagine it does fit and you install 2 units - that will be 28 lbs of iron there. 🙂
