Just a tip: if anything goes not like it should be then your amplifier will amplify anything it sees at the input to the max....At least I have experienced this with other peoples stuff (which I was to check/repair) and digital volume control of the source or DAC. The famous "odd bit" that somehow sets output volume of the DAC to max for instance. Family members that put volume to the max with Spotify etc. Other issue can be that volume is OK but loud clicks are heard when changing tracks etc. Also switching off the DAC while the power amplifier is still powered on might give unwanted effects.
Nothing goes wrong with a "real" volume control in between as the volume likely will be at normal levels. It acts like a kind of protection.
That's true. Hardware volume control provides a secondary protection against unforeseen volume surges.
I am playing with various volume control schemes for fun. One of them is the typical volume pot. I implemented mine with a 10k linear pot, and surprisingly it worked out pretty well.
I also implemented a discrete volume control using jumper caps. It had 4 possible volume levels. I believe it could be similar to a scheme mentioned by Claude, but cannot be sure. It also worked out well. Here is the drawing:
The smps PSU you are using is really bad I own it. It has a Bad ripple.
You should get a LLC with a good ripple and low noise.
The PSU has very important Impact in term of SQ
Can you provide any information on the Allo board? I assume you are a tester for them as the only acknowledgment about the board's existence I can find is from you.
Will it be in the same format as the existing Allo Volt boards? Specifically, will it be a standalone board or will there also be a version with standoffs to connect directly to their DAC boards? Also curious if this is a dual mono design. Sounds like this will be the widely available board to get.
the tpa3255 arrived, checking the diagram I saw that for the input capacitors they are indicated not polarized, so I assume MKP or similar. Can someone confirm me that they are those indicated on the amplifier but they are electrolytic? ...
Look at the black stripe on the capacitor, which is the negative terminal of the polarized electrolytic cap.
has anybody tested the Shui Yuan Audio TPA3255 - board with more than 48V (maybe 55Vmax idle)?
Why would you do that? Are you running a high impedance load?
I am not specially a tester. But I am in touch with Allo's founder. All I can say for the moment : should be a finished amp with some innovations : Air Core inductors, ultra low noise PSU, new op amps, high Audio grade caps etc... The amplifier would use balanced inputs. I shared the measurements a few pages back...(It will be by far the best TPA3255 on the market)
I am waiting for the sample but the project is late, should get some news in a few days.🙂
Forgot to share this, discovered a new TPA3255 with WiFi DLNA AirPlay2 functions )
CLOUDYX CL-300W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm - Audiophonics
Hi!
They begin to doubt their amps at 400 euros ...
Note: This product offers many features, only its design with integrated DSP does not offer the transparency sought by audiophiles. The analog input also goes through the DSP through an ADC. We recommend it for someone looking for a network amplifier that supports many music services and protocols with comfortable power, but without high fidelity requirements.
Better and better ... Audiophonics .... Long live the DIY !!!! 😛😛😛
This site is starting to get on my nerves ...
Amplifier with chips from 2008 ...
Cable out of ..... price .....SUCA AUDIO DA-2120C Amplificateur FDA Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Noir - Audiophonics
Stay smart and don't give in!
mamocel, I hope your Akita amplifier arrives as soon as possible, I await your opinion on how it compares with your class d pcbs 😀
Hi friend!
It's on the road .... but the follow-up is not easy ...
he left russia. May 9 ...
The weather is starting to be fine, nature is waking up ...
In short ... Lots of things to do ....
And when my wife and here... I have to do something other than tinker with my amps ... (it gets on this her nerves) ... 😕😕😀
Shui Yuan Board is on sale US$14.80, without shipping..
grab as fast as you can
shui yuan Audio TPA3255 2.0 Digital Amplifier Board DC24 48v Strong High Power 300W + 300W Class D o Digital Amplifier Board|Amplifier| - AliExpress
Good find. I was literally staring at this board yesterday trying to decide whether to buy it or Aiyima A07.
So I'm trying to find a soic-8 to dip-8 adapter board since my squareish pins didn't fit, but I'm struggling a bit, not knowing what works and not. Has anyone a tip where to buy ones that work for this application?
Hi
Yes you are right - the square pins will destroy your IC Sockets as they are too big !!
You need the “round pin” headers. Normally come in strips of 40. Here is an example :-
10PCS/LOT Gold Plated 2.54mm Male 40 Pin Single Row Straight Round Pin Header Strip|header female|header bagstrip thermometer - AliExpress
And then you need the adapter boards. Loads of people selling these !! Something like this :-
50PCS SOP8 SO8 SOIC8 TO DIP8 Interposer board pcb Board Adapter Plate hot diy electronics|Integrated Circuits| - AliExpress
if you really need a potentiometer ....
ALPS RK 27 ...
This one sounds not very good (blurry and smeared) and is technically mediocre at best. For this low quality far too expensive. Either buy a cheaper one or a better one which would sound light-years better (TKD or stepped with good resistors).
What is the current demand on this one?
Hi
Thanks for the tips! Now just to kick back and wait for more china post... 😛
- Class D
- Shui Yuan Audio TPA3255 Modification Thread
