Salas SSLV1.3 UltraBiB shunt regulator
13.5V at the output/100R dummy = 135mA. It should have had the power to reach more output voltage with 300mA CC confirmed available. All your DC state readings are logical. Do you have an oscilloscope to check the negative rail for some possible oscillation?
Dear Salas, I found the mistake. I made my own board and falsely oriented Q2 and Q3. Collector and emitter were switched. I'm very sorry I've bothered you but I just can't believe I did such a stupid mistake.
It is interesting to me how transistors were 'working' that way - I would have never thought it's possible. Now I can finish my DCG3. 🙂
Just one more question: will single pair of SSLV1.3 be enough to supply both channels of DCG3 or would you suggest to build one for each channel?
Thank you very much for your help and paciance!
P.S.: A picture of DCG3 and SSLV1.3 (with additional input filtering)
Takes not only more space but yet another dual independent secondaries transformer and higher total shunt PSUs dissipation nonetheless.
Although you would notch down the CC current burden per reg in dual mono, the minimum spare current dissipation remains the same and multiplies heat by the more reg units.
I have build 2 ultrabib positive regulators and cannot get them to run.
I attched a toroid transformer with 30vac output and used a saligny mosfet rectifier. R1 is below the pcb.
On both regulators I get 3,45v output and cannot set the voltage.
Did I make an obvious mistake?
Hope you can help.
Kind regards,
