Semisouth Aleph J?
Very nice! Another nice thing about that LTP bias arrangement – since gate and source are tied together, one could also use a J113 (or other comparable JFET) by flipping the device opposite of the screen.
Didn't thought about it but you are right. 🙂
2SK170/2SJ170 - DGS
J113 - GSD (ON Semi, NXP) But J113 by InterFET is GDS
P.S.: Slightly corrected layout for more pretty symmetry.
> can perfectly make that CCS with ring of two bjts
A J113, as used by Nelson, with a source resistor is much simpler, and it is still fully JFET.
Also costs nothing.
And according to Walt Jung, better in performance (Fig. 3B, 8B).
https://audioxpress.com/assets/upload/files/Sources_101_P1.pdf
Patrick
I found this post by Patrick of Walt Junt article about Audio Current Regulator tests.
What do you think if I add JFET cascode to input JFET CCS like in the article?
I also looked what everyone tryed as JFET cascode to 2SK170 and.. Patrick also suggested J111 since about year 2008. 🙂
Here is a concept layout.
It may look strange right now.
R8 is a jumper/zero Ohm resistor in this one.
ygpm, too
ring of two is best you'll ever need , in position as this one (input LTP CCS)
observe Stasis new FE - for Pa - even simple/sole bjt is goodenough as CCS
ZM being Chicken, I always go to double, compensating lack of knowledge, education and courage - with number of parts
though, can't argue if someone have a Fetish for JFets, so even CCS must be JFet one
:clown:
post 138, you'll recognize T of LTP
About possible Babelfish J interest
"ring of two" , in/according to some sources meaning slightly different circuit - with more symmetry but also with some additional problems
however, I did found same reference for this exact circuit of CCS, and it was easy to remember from first day
later I did found reference to mentioned iteration, but who cares, as long I know what I'm thinking of
:rofl:
I am not sure if such long traces, allocated to input signal routing to the JEFT's, are going to pose any risk with regard to possible oscillations...? I haven't checked what the input impedance of your design (schematics) is neither...
It is very hard to know if the input section of the PCB will cause any instability due to layout; sometimes even the completely surrounded traces, with a ground fill, could cause issues. I suppose the best is to try and see..???
Have a look at Marantz PCB layouts, CD players and amplifiers. The service manuals are readily available for download.
Compare the original designs (PCB layouts), with Ken Ishiwata (KI) designs (PCB layouts). You will notice the difference in how Ken was routing common returns on "KI" models, and in how he distributed the supply rails.
It was a common understanding that Ken used "specially tuned for audio" parts, to make the KI models sound better compared to the original. But, I think that the PCB layout differences (that not many picked up on) made the biggest - (almost) quantifiable differences.
