As you can see, they have a cool choice ....
Just choose your options.
They came to France in 7 days ...
Stronger than the Russian and Chinese post ... (DrMordor not your fault)
There must be a lot of officials in Russia and China ...
To control the people ... and the incoming outgoing
I reassure you in France ... it's not better ...
On cimarron site?
No customs fees ...
14 dollars postage ... All the same!
Should I order the opa1612, then on this page ...😉
I wasn't going to push you into compulsive shopping ...
All the same !
But that would allow me to know your opinions ...
And share with the rest of the world! 😉😉😉
I take this option: SOIC-8 to DIP Adapter - BrownDog Adapters - 970601
16,80 dollars for one chip....
All the same !
yes the price is high, i have a local dealer who could order op amps from mauser, i hope i can solder them on the adapter.
It seems to me that Daniboun had found adapters which do not require any soldering ...
Otherwise good luck for the solder .... Presbyopia does not help .... in any case ... not for me ...
Fortunately I still have good ears ...
Despite my repetition of music with marshall at the limit of the listenable ...
ok thanks, i try to ask daniboun.
At 53 years of age I hear less high frequencies but I don't complain.
Vitaly, I read that you ordered the ADA4610-2 how do they feel about 1612, 1632. 1656, 627 ....
these are the solderless adapters posted by @ daniboun, right?
https://m.fr.aliexpress.com/item/32...earchweb0_0,searchweb201602_,searchweb201603_
I found the links ... Obviously you have to solder the support ...
Adaptateur Tulipe SOIC 8 Clipsable a Souder sur Circuit Imprime - Audiophonics
Mamocel,
They are also used for programming .. or?
Very good opamp))) My new idol)))
great, it will be difficult to weld.
Strange, I see some iron wires or cables soldered on the external pins
now i understand, the op amp is too small to be soldered on the adapter so you soldered the iron wires to the outer pins
I wait adaptor MSOP8>DIP8
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
