DAC AD1862: Almost THT, I2S input, NOS, R-2R
Joined 2007
Here 2 pics I have available. PXL_20210501_165231412.jpg PXL_20210501_165318309.jpg
Joined 2007
Thanks guys for your answers!
Fran, strange thing is, that they come from the appropriate location,
and as I see this, the board does not let me make any mistake here. There is a direct connection from pin 7 (data) to the appropriate shift register. Continuity check was done.
the dac choice in the playback renderer perhaps :confused: ?
If your smd caps are not ceramic class II, better to go for ceramic class I, or sorted out PPMS if you have some in your tool box from another project anf id its width fits the vias gap.
Iggy, I had tried some different ones, yet the generic i2s should be ok. I also checked, if volumio, which I used, was switched to the left channel only, even this never happened before. Yet I did not find a swith for that within.
I used Miros "original" BOM (in this case from EASY DAC) for that. TME delivers just 100 of them, so there were plenty. Maybe I find some others in my drawer.....
Good idea to use c0g caps on underside near shift registers.
Maybe there is a fault on underside, wrong connection to GND from latch enable signal i would check that fitst
Tubee, I had done all the check for shorts and I did it again. No short between grd and lrck.
So hopfully I get set up a very old USB2i2s board (from first DDDAC) and will be able to test it again.
Will report back.
Have a good day :)
Joined 2018
I have now some of Vunces opamp adaptor boards for trying 1656.
In the schematic it shows the 2 smd resistors as 47k5 but you have 100k on your boards. Should I go with the 100k also.? And I assume 100nF on the underside.
What pins do you use for these little boards. The pins I've used before are too short...or atleast the holes in the boards won't allow for the shoulder of my pins to enter.
Thanks!
Joined 2007
Ja, my IAN DAC is a cable grave. Yet a pretty good sounding one with dcdc less pi, old Andrea clocks, fifopi3, receiverPi, which accepts USB board and spdif. And I like the transformer i/v. So it is a full blown network DAC which deserves a chassis and of course cleaner cable work. One of the next projects. After the easy DAC.
