RIAA using ECC88 tubes
Because the filament supply is DC, the hum is not coming from that source.
Can you disconnect one ECC88 at the input without much trouble?
O.K. I must have mixed up two threads here concerning that MM stylus. Sorry, but still it is interesting to do the job with only one ECC88 in front.
Without examining the "DC" one cannot say "he hum is not coming from that source."
Same goes for B+, measure to be sure that both these are clean.
Then one should examine earth-loops and transformer placement and connections.
Here is the text relating to the circuit, i haven't had a chance to try any suggestions to remove the hum yet - I will have a go tomorrow and I will also post a picture of the unit if I still can't get rid of it. Thanks for all your replies
Heater earthing
Is it perhaps possible for you to take a picture of that (hardware) layout? So we can also benefit from your experiences. :)
Picture as requested, I have put text where I added an earthing resistor to the heater supply. I still need to tidy the wiring and change the input / output cables for screened type but it's all coming together nicely !!
Joined 2004
"input length there is 1M from the turntable so I can’t see 4 inches making much difference"
Phono cable from turntable to phono preamp is shielded.
You wiring inside the phono amp not, and there are some magnetic field from transformers.
If shorting inputs no significant hum, you are a lucky man, but in general the phono input wires must be as short as possible, if it not feasible, must be shielding!
